- 30 May 2007
- Glasgow, Scotland
Chav incoming in 3, 2, 1
The dog or the sofa?
mmm, nothing screams cold, uncomfortable and dull quite like a brown leather sofa.![]()
Would you mind telling me where you got the TV Unit/name?
Thanks, @Marvt74 - appreciate the price info, too, good to know.It was this one
https://www.wayfair.co.uk/furniture/pdp/world-menagerie-tejas-tv-stand-for-tvs-up-to-70-bmh1645.html
Shows as out of stock though, also we only paid £270 so not sure why it's now double!
There are some similar looking ones though.
Excellent - thanks.Life hack - Take image used by websites, reverse image search, will get you results of other suppliers using the standard stock image.
It gets better : https://www.phoenixhomeinteriorsonl...ed-painted-boat-wood-black-metal-frame/126323https://www.woodpeckerinteriors.co....led-painted-boat-wood-black-metal-frame/46399
I think i'll stick in a picture of a young Christina Hendricks in next - and see how much she costs![]()
Either that's a midget door, or your ceilings are incredibly high?
Managed to get my hands on a Brand new, still sealed in shrink wrap Voodoo 3500! The seller was brilliant, big outer box, triple bubble wrap, and clear plastic to protect the shrink wrap! I'll never be able to bring myself to open this beauty!
Do you have sort of fetish for old graphics cards?
He'd have to be careful if he does, all bodily fluids are conductive.
I actually forgot about this for months having previously made a mental note to replace...
Noticed one day the extension green lights for surge protection going into the desk setup were out, a quick google revealed once the light is out or dim it's time to replace the extension as it's no longer providing surge protection. How do people check surge protection status on outlets and extensions without an indicator??
^^ These are around 8 years old so a quick search on Amazon later I found a 12 gang socket designed for server cabinets but usable around the home. Some reviews stated various sockets wouldn't allow anything to be plugged in, possible QC issues etc but I found the same one on the Kenable website for a few quid cheaper and once it arrived, all sockets worked fine, no buzzing which was something else a couple reviews mentioned either. Nice that it's modular, you can swap around the brackets and the side the power inlet cable goes into.
