What's likely to be the value point for 4K gaming then?
Right now 4K gaming at high settings is completely GPU bound.
So on a pure perf/$ basis you can get away with something like an overclocked 3600. For a Zen 3 chip, 5600X is plenty.
That will be the real fight on review day.
I reckon the 5600X will crush the 10600K and give the 9900K/10700K a close run.
It's got 8 cores?So overall the 5600X is the better CPU, and now price does matter, i've said it before i'll say it again, the 10700K is a £220 CPU, why else would you buy it over the 5600X?
I see holes in AMD's lineup. Where is the Ryzen 7 5700X at 65 watt?
5600X is not plenty, in gaming at 4K you will get the same results with Ryzen 3 1400X.
The games for some very weird reasoning don't accelerate their performance via CPU scaling like normal multi-threading apps do..
It's got 8 cores?
Oh sorry I thought you were comparing the 5600X to the 10700K.The FX-8350 had 8 cores....
I don’t think a 5700x is needed tbh...
What about those that would like an 8 core Zen3 generation chip that costs around the same as the 3700x did at launch? ($329)
There is room for a 5700x but doubt we'd see anything until 2021
Would make the 5600x pointless in the stack at $299
The 3600 was $199.
Ryzen 9 3900X 12-core for $499. Now you have to pay the same amount for Ryzen 7 5800X 8-core + your own DIY cooling.
The 5800x is $449??? Not $499
