- 29 Feb 2012
- London
Will new mobo's be released as well?
4000 is mobile I think.Was there a reason they skipped the 4xxx name and went straight to 5xxx?
Will you be providing a bios update on motherboards? As I don't have a gene cpu
Again CPU's can be ordered 5pm on 5th November, we also expect to have product on the shelf and I have ordered thousands of CPU's so if our demand is met then supply for OcUK customers should not be an issue.
@Gibbo
Will you be shipping these CPUs (for people who order them quickly) on the 5th? So that they're delivered on Friday 6th? Would be good to have them on Friday so that we can do the upgrade/build over the weekend!
(5950x fo me)It's going to be tragic when FX fluctuations mean all CPUs will cost +20% more on release day. Or for a similar reason
If your main use is gaming and you play at 1440p then go for Zen 2 and save a wad of cash as it wont make any difference for gaming at that res. put the cash saved into another another area of your PC that will make a difference to performance or QoL.I don't know which one I want, I currently have a incredibly quiet system using a NH-U14S. I am swaying between the 5600X and the 5800X, I play at 1440p...
