@CAT-THE-FIFTH beat me to it anyway, its a duplicate thread, i reported it so its about to get nuked.
Should be good for 5 years atleast.People, when do you think the 5900x will be equivalent to the 6600k?
By which I mean - until recently I was in a 6600k and was going to upgrade this generation because most things were bottlenecked by the CPU. So I had that chip around 4.5-5 years before it no longer held up in gaming.
How long do we reckon until the 5900x again reaches that same point?
Edit to add: Because I'm weighting up a very long life Vs high price
I am not having any difficulty with anything. You just can't handle being proved to be contradicting yourself and saying that to save face. It is easy to see.Manual overclocking was worthwhile back in the day. The comments were directed at TNA who doesn't understand the difference between the two.
I manually overclocked a gpu way back in the day and I used software to unlock 2 pipes that had been software blocked so I managed to get a £300 gpu for £120 after clocking and software modding. That was over 20 years ago when I was a kid at high school.
I also manually overclocked my 2500k because that went from good to crazy speeds with overclocking.
However I never bothered with Ryzen as it was already very well tuned from the factory. It was pointless spending 3 days to get an 50mhz and stability.whereas with the 2500k I got an extra 900+ MHz so was worth the effort.
Now I can click a button.so it would be stupid not to.
I'm saying that for the majority software overclocking is quick, easy , safe and it undervolts too and because it can analyse each individual core it's probably better longer term in terms of stability and voltages.
I know the 2500k needed a bit more power to be stable after 5+ years of overclocking.
TNA is having issues with differentiation between the two.
I'm saying manual overclocking in my opinion is pointless. Especially since it gives minimal gains for the time and effort involved.
Clicking a button though. That's progress and easy.
6600k is different from Zen 3 as it was gimped from the start. Main reason why it's bottlenecking now is the lack of HT.People, when do you think the 5900x will be equivalent to the 6600k?
You can't have 30K+ posts here, spend ages replying to me with a bunch of woffle again like last time and then say you have better things to do with your time
I did a manual overclock, got a very good boost on my 3600 and enjoyed every moment of it. So zero time wasted. Whether it is a waste of time or not is not for you to say, that depends on the individual, if they enjoy overclocking then it goes under the fun category not waste of time. So jog on and stop "wasting time" replying to me![]()
What about B450?
Anus.
What about B450?
ROG Strix B450-F Gaming II delivers all the essentials needed for a well-balanced build. Designed to handle the latest 3rd Gen AMD Ryzen™ and beyond,
If I have to buy a 500 series board to use these chips then the slim chance of me buying one has just evaporated.
That is bound to be included, they even refreshed B450 boards recently and in the marketing it states.
It looks like you're running an Intel CPU in your sig. Needing a new motherboard for a new CPU should be something you are accustomed to.
This is an example of the excellent customer service ASUS provide, and why they can charge a lot more for their products.ASUS says its not providing BIOS update to enable Zen 3 support on x470, ASUS will only support Zen 3 on B550 and X570
https://www.reddit.com/r/Amd/comments/ja23gg/asus_wont_provide_bios_update_for_x470_board_to/
I did the same. However, I ran the tool first to obtain the limits and recommended vcore and frequency. Then I did it manually with some minor adjustments.
