Caporegime
- 9 Nov 2009
- Planet Earth
Don't buy the Asus one,as they CBA supporting their previous ones properly. MSI or Gigabyte seem like better bets IMHO.
Take a look at the ZOTAC GeForce GTX 1660 SUPER if you register within 30 days you get 5 year warranty instead if 3 years.
Your welcome, it does have gddr6 but I'm sure you'll be happy with MSI.thanks, I have ordered the msi 1660 super. It has gddr6 checked the zotac and it only had gddr5. Thanks for your help. They might have 3080's in stock later next year LOL
Was about to ask this question. Why even go for x570 at this point? Is there a catch I'm missing somewhere?Except they cost more than a MSI MEG X570 Unify right now, which itself is a non-RGB variant of the MSI ACE retailing at £330, and a lot more than the Tommahawk X570
What are they actually offering here for the customer that X570 doesn't do already incl. price points?
well B550 was supposed to be the value oriented PCIe4 alternative to X570 it benefits from not needing a chjpset fan but otherwise is restricted on the number of PCIe4 lanes it has to share. There are some really good B550 boards but they are more expensive than many of the X570 ones now they are coming down in price.Was about to ask this question. Why even go for x570 at this point? Is there a catch I'm missing somewhere?
So If I am interpreting this correctly, overclocking is tad bit more limited on the B550 no matter how high-end it might be?well B550 was supposed to be the value oriented PCIe4 alternative to X570 it benefits from not needing a chjpset fan but otherwise is restricted on the number of PCIe4 lanes it has to share. There are some really good B550 boards but they are more expensive than many of the X570 ones now they are coming down in price.
£ for £ B550 vs X570 you'd go with X570 surely, at least decent VRMs and cooling.
Not really as both will overclock just fine, even my B450 can OC without issue.So If I am interpreting this correctly, overclocking is tad bit more limited on the B550 no matter how high-end it might be?
The X570 tomahawk is a great board at just over £200I see. Any recommendations you guys can give me for a x570 around £250?
No not necessarily, the B550 has less PCIe 4 lanes in its arsenal and CPU to chipset is PCIe 3. Where it starts to make a difference is connecting lots of cards, storage and peripherals... If say you only ever want to use 1x GPU and 1 x M.2 storage you wouldn't notice the difference but go higher than that the compromises on how B550 divides up the lanes starts to creep in.So If I am interpreting this correctly, overclocking is tad bit more limited on the B550 no matter how high-end it might be?
The tomahawk slightly outperforms the unify in VRM temps but that said they are both great boards.No not necessarily, the B550 has less PCIe 4 lanes in its arsenal and CPU to chipset is PCIe 3. Where it starts to make a difference is connecting lots of cards, storage and peripherals... If say you only ever want to use 1x GPU and 1 x M.2 storage you wouldn't notice the difference but go higher than that the compromises on how B550 divides up the lanes starts to creep in.
For good overclock potential you basically need a £200+ board atm as that gives you the quality components that gives you the best chance for higher frequencies but also better cooling (less crashing). The Unify for example uses (I believe) a superior VRM controller to the Tomahawk that might make a difference or it may not.
I'd look at the MSI Tomahawk, Unify and the Gigabyte Aurous Elite. The new boards recently announced my MSI and Asus I think are all £280-£350, if you shop around you might get a Unify for £250. One thing the reviews don't tend to cover or have changed over time is the Unify price has come down from £300 to £260 and the Tomahawk has gone up £210+ due to its popularity.... so the lines are blurring. If you are on a budget Tomahawk is where I'd put my money, if you want more you pay more...
VRM temps are both good, on the Unify you have extra M.2, extra PCIe x16 slot, better VRM controller, bluetooth 5.1, OC cmos reset, post code LEDs etc... Basically if you're intending to tinker, push the OC's and experiment with bios versions or believe you'll end up with 3 M.2 storage then the Unify has you covered that's what you are paying for. Does it mean extra performance? Probably not it means you can push for the extra performance and there are some nice bios updates on the Overclockers.net forums
Unify is the better board for a higher price just as the Godlike, Ultra and Extreme are better still but for an even higher price.
Are these custom BIOS updates? Can you point me in the direction of them please.
Tomahawk has bluetooth 5.1 just to point out.
X570 have extra pcie lanes and more ports.So back to the OPs original question.
I am considering a Tomahawk, but am still on the fence as to B550 or X570 version.
VRM wise they are the same, I don't need the wifi and I only have one NvME for OS which is gen 3 anyways. Main storage is currently a hybrid 2tb, but may in time get updated to an SSD.
I will look to be running a Zen 3.
Considering not many people can even tell the difference in sata SSD to NvME in a blind test and the cost difference is £50, what am I missing out on by going for the 550 ?
Yes that's correct.Which , as far as I can see, makes no odds to my setup.
Ill only be using one M2 and one sata, or at most 2 m.2 and 2 sata in the future, no add in cards apart from GPU.
I'll have 2 less USB 3.2 ports on the back,, but I am sure hubs will be available when more 3.2 devices become mainstream.
In terms of overclockability (if the new cpus even have much headroom) there won't be much, if any difference as the 2 tomahawk boards use the same vrms and have essentially the same memory oc speeds (again probably irrelevant as likely tied to the cpu).
Is that a fair assessment, or am I missing something ?
