So if a quad core comes in at £300 is that ok.?
If its faster than a £300 8 core? Yes.
I don't see why a 5600X will beat intels top line in single core.
I don't understand the fixation on number of cores. For a given performance level it's better to have as FEW cores as possible.thing is its a a 6 core. ideally you wanna be going 8 especially if keeping for a long while
And in case of 5600X vs 3700X, equal in multicore
That is a very, very general statement. It depends on what you do on your PC. If you just game and browse then yeah, you can get away with 4-6 cores. But the moment you start doing productivity tasks of some significance and those apps are multi-threaded and take advantage of more cores, then going to 8-12 cores will wipe the floor with them. Games are also slowly starting to take advantage of additional cores.I don't understand the fixation on number of cores. For a given performance level it's better to have as FEW cores as possible.
Yep, in a perfect world, we'd be running blisteringly fast single cores. There's nothing to commend multi-core, the only reason why super computers went down this route 40 years ago and PCs more recently is the limits of single core performance. There are overheads in multi-core architecture.So long as its as fast as the previous gen 6 core then I guess some people are happy with this![]()
That is literally one of the most ignorant and/or hyperbolic statements I have ever seen on this forum. I mean really, just... lol...There's nothing to commend multi-core
An 8-core CPU is the current sweet spot for gaming and productivity performance... it's a shame the 5800x is so pricey at launch.
I think you've totally missed the point he is trying to make.That is a very, very general statement. It depends on what you do on your PC. If you just game and browse then yeah, you can get away with 4-6 cores. But the moment you start doing productivity tasks of some significance and those apps are multi-threaded and take advantage of more cores, then going to 8-12 cores will wipe the floor with them. Games are also slowly starting to take advantage of additional cores.
Who made those slides?
We haven't been made aware of reviewers even receiving copies to assess as yet, have we?
No, this wrong. A single core CPU with the same raw performance as an 8 core will be faster, in everything. There's a overhead to multi-threading better to avoid.
If it does then all the 5000 chips will destroy intel in gaming.
Its unlikely this will be the case, only the higher end ones which have the higher clocks.
We will wait and see, but I'd be utterly amazed if a 5600X beats 10900K in single core CB r20, hope it does though.
So basically what you are saying is: "In a theoretical fantasy world that does not exist, a single 6 or 10 or whatever ghz core with insane IPC would be the best option", despite there being no such thing in the x86 world and likely never will be due to clear technological liitations? That wishful thinking makes multiple cores have "nothing to commend", despite the fact that they DO offer a lot of processing power?I think you've totally missed the point he is trying to make.
Multi-core is a necessity at this time because AMD / Intel have struggled with high IPC, high-frequency cores. In order to keep improving performance for multi-threaded applications, they have had to increase the core counts. Applications that don't have many threads suffer as a result.
If you had a sufficiently fast single core, it could do the same amount of work on a single thread in a fraction of the time freeing up other cycles for the other threads meaning it can execute just as many threads in the same time as a lower IPC, lower frequency multi-core.
This theoretical core would also process less threaded applications much more quickly.
You don't need more cores because you have more threads. You need more threads to make use of more cores.
Indeed, but if we had supper fast single cores, we wouldn't have multi-threaded software.There's also an overhead when trying to processing multiple threads on a single core.
You and him are engaging in fantasy and then making very silly hyperbolic statements off the back of it.
What fantasy?So basically what you are saying is: "In a theoretical fantasy world that does not exist, a single 6 or 10 or whatever ghz core with insane IPC would be the best option", despite there being no such thing in the x86 world and likely never will be due to clear technological liitations? That wishful thinking makes multiple cores have "nothing to commend", despite the fact that they DO offer a lot of processing power?
You and him are engaging in fantasy and then making ridiculous hyperbolic statements off the back of it.
I know what point is attempting to be made, but I think it is irrelevant to the reality of the current CPU landscape.What fantasy?
Someone questioned if you would buy a 6 core over an 8 core if it is faster in ST & MT applications. The simple answer is yes you would and everybody buying a desktop PC should.
The rest was used to illustrate that it doesn't matter what you say about 8 core being a sweet spot, the number of cores is irrelevant when assessing the value of a purchase which can only be made against it's ST & MT performance.
Any hyperbole is your doing by failing to grasp the point being made, and talking about 'sweet spots' and the like which have no impact on the statement.
