Man of Honour
- 8 Nov 2007
- Outer Space
Hey all,
Does anyone have one of these kits?
https://www.overclockers.co.uk/phan...0mm-pci-e-x-16-riser-cable-kit-cm-02u-pt.html
I'm thinking of getting one but concerned over the included cable as they also sell a premium shielded cable separately, so is it worth getting both and just using the shielded cable instead?
Does it have any impact on GPU performance, stability or anything else I've not considered?
https://www.overclockers.co.uk/phan...-riser-cable-90-degree-adapter-cm-02p-pt.html
Thanks in advance
Thanks in advance
...... I saw in another thread you mentioned you had a Phantek case and something about an asus cable?? may I ask which one, and did you go for a full adapter kit that fills the expansion slot area, or just the cable to use any vertical slots closer to the side panel ?
