- 12 Sep 2011
Can i suggest that instead of updating the graphics card stock thread with "an ok amount" or "" a fair few" or similar you actually post specific numbers Gibbo of specific SKU's
This is no more effort and this serves a couple of purposes
As your already aware people are being given a que number via a periodic email for their specific SKU's, so this will then give them clarity of how far up that que they are climbing number wise without the need for them to message support to ask if instead of saying "an ok amount" you said something more like
"25 units of Asus Strx 3080 OC are coming tommorow" - that would be far more helpful
Secondly it simply shows clarity as stating an "ok amount" doesnt give any at all and insinuates either you dont have a clue how much stock really is coming in (which lets face it is extrmely unlikely) or some of the stock from the "ok amount" are being shifted elsewhere from those shipments because not being specific with numbers leaves the door open for that to happen doeesnt it.
Or is there a specific reason that the actual numbers being shipped are not being specified Gibbo that you havent perhaps told us?
For example do you order, say 500 units, and some simply appear that you then tick off the order ?
Obviously i doubt this as no right minded manufacturer would simply fill a lorry up with £800 units and not know what they were sending, they would know a number.
Otherwise you could simply say
"we only got an OK amount, sorry guys" and pay them for half that delivered
Why is it the amounts being delivered to you are so vague Gibbo in that you know whats coming but not the amount and for example what in your mind does "an ok amount" actually translate to ?
I ask because i have totally no idea reading your posts what that means as regards my que number, its about as clear as pea soup and simply translates to "someone somewhere might get some cards"
Could you perhaps do some sort of table for clarity for example
"Some" = 5-10
"An ok amount" = between 25 and 50
"A fair few" = 50-75
"a box full" = whatever that number that box contains
"a bakers dozen" = 12 with one spare for ebay
Im pretty sure this is the general feeling here and that people would like to be able to work out where they are are in their respective ques regards whats coming in and the likely hood of a delivery taking place for thier debited accounts, getting numbers would go some way to reassuring them.
Or is that us being a bit too fussy and expecting too much ?
"Some" = 5-10
