As long as you stick with branded stuff you should be fine whichever you choose.
Crucial Mx500 seems to be the best budget drive. Avoid dramless drives like the crucial bx, sandisk ssd plus, WD Green (and perhaps blue too) etcI thought that might be the case , I just wondered if one stood out for having a larger or faster cache...
You've already been subjected to the wall of text I put up on dramless SSDs.While I agree in principal, in the real world, it tends to make bugger all perceivable difference outside of synthetic benchmarks that are irrelevant to how most people use the hardware.
Well look at mister smarty pants over here. I'd like to see where people talked about the sandisk ssdplus bait and switch if it was so discussed.Yes, but by your own admission, you kind of suck at hardware purchases, a no name Chinese drive (though the TCSunbow stuff is essentially the same controller set-up as Crucia MX500 from memory if you want cache and cheap) and somehow managing to miss one of the most discussed bait and switches in SSD history since Kingston, those are hardly shining examples. In the right application they work well, and in load time tests they generally come in almost indistinguishable from anything else, which makes for cheap/fast steam library drives. Then again I normally run fusion.io's that cost a fraction of your average SSD and have write endurance my kids may have to worry about long after i'm gone, who doesn't like 3.8TB for less than the price of a 2TB QLC NVMe drive?
MX500 isn't exactly budget drive.Crucial Mx500 seems to be the best budget drive.
You after one with or without dram cache?
A report from TrendForce suggests that SSD prices are expected to fall between 10 and 15 percent in the coming quarter due to an oversupply issue.
Over supply,, More like the they cost far to much ..Around £700Typical![]()
 for a 4TB NVMe so people not buying them
