quick FreeSync question
27 Jul 2005
The Orion Spur
I'm thinking of grabbing an AMD GPU for the first time in well over a decade, a big part of that is due to the G-Sync premium on monitors, now what I want to know is the following,
If I have an AMD gpu and pick up any freesync monitor is it guaranteed to work with it properly, or is it a bit of a crapshoot like pairing nvidia gpu with G-Sync 'compatible' display?
Nvidia GPUs work with most Freesync monitors btw. Using one now and its working great.
I hear this a lot but is there a list off 100% compatible monitors? just seems there a lot cheaper freesync screens out there like the recent budget Gigabyte ultrawide (G34WQC) but people people on Nvidia GPU's have reported flickering, I like things to be 100% compatible otherwise I find it very irritating.
Yes, sort by Gsync compatible on this list
https://www.nvidia.com/en-us/geforce/products/g-sync-monitors/specs/
Fwiw I'm using a iiyama ultrawide that has freesync with my GTX1080 and no flickering so far.
Thanks for your help but you kind of make my point there, there are only two 3440x1440 ultrawides listed there, the cheapest being £969! On the freesync side you can pick many 34" 3440x1440 ultrawides around the £400-500 range, that's a massive price difference, the cost of a good GPU.
You show me a cheap 100% g-sync compatible ultrawide and I'll buy it.
Yup I do agree with you and see what you mean, however it's not so black and white - like my monitor which cost £429 and is working perfectly well with Gsync.
I've managed to get a 34" Iiyama IPS ultrawide for £385 today - https://www.overclockers.co.uk/iiya...esync-ultrawide-gaming-monitor-mo-13j-iy.html
I'm running a 1080Ti at the moment on an Acer xb271hu which is full g-sync as it has the actual g-sync chip, so I will be comparing it when the new monitor arrives. Hopefully it'll function the same, and I won't be tied to a specific GPU vendor.
I'll let you know how I get on!
Interesting thanks, definitely report back.
