Are all 3090 cards with two 8-pin power connectors limited to 375W? 150W (8-pin) + 150W (8-pin) + 75W (PCIe).
Is this likely to be a problem? Are there any gains to be had from going over 375W, or is it diminishing returns beyond that point?
The reason I ask is that I have a Gigabyte Aorus Master on order and I've noticed that it only has two 8-pin connectors. Why would Gigabyte only have two power connectors on a relatively high end card? I know the Aorus Extreme has 3 power connectors, but it seems a bit short sighted to deliberately cripple the Master.
In an ideal world and leaving all options open is great.<snip>
there is a gigabyte 390watt bios out.
slightly exceeds the 75watt pcie slot power I believe...
but yes try and get a 3x8pin card for 450(500max) watt overclocking.
gains maybe 1000 points in time spy in games maybe 1 fps if your lucky...
(currently)Haven’t most of us spent a extra £800 or so for 3090’s That only give 20% or so performance over 3080’s?”the extra few fps you potentially get for the extra £50 or £100 isnt worth it for performance per cost - paying up to 10% more for the card to get you a chance of 2-3% more performance.”
We wont get an update unless there is something to tell us, which there is not(currently)
I’m glad I ordered the Strix before I knew to much that some had 3 pin power some had 2.
I was lucky in ignorance.
I just wanted e peen£800 for 20% to 30% (£26 to £40 per percent gain) is better than spending another £200 for one with 2-3% (£66 to £100 per percent gain)plus not guaranteed as its all about the silicon lottery. Also although some people have preferred to have spent less, some needed that extra performance if running a 120hz 4k screen. The 3080 just didnt quite cut it. I am sure if there had been a £1000 option offering 95% of the 3090 performance then that would be the card everybody would be buying.
I think so far the best performing card from owners on here has been the guy who got lucky with a Pallit 3090 which has only two power connectors but runs all day long at 2100 boost.
There will be a lot of strix OC card owners who wont even match his card never mind beat it. But they will have a nicer looking card and more RGB![]()
i'd love to see that hold 2100 at 4k lol no chance.
wonder what volts its keeping the core at to keep under the PL.
It would be interesting to what overclock he has on the card and fan curve to achieve this.i'd love to see that hold 2100 at 4k lol no chance.
The competitor have updated today that they are expecting over 100 3090's this week, across the various brands.....that should clear an 1/8th of their pre order book!
Also 300 3080's
