the 3080 will have worst textures than the digital PS5 which is like half its price in 2 years time lol.
Grade A nonsense.
Buying a 5900X and a 5900XT sounds like the best performance you can buy, which is incredible.
But in terms of options for consumer's, were still getting stuffed.
You keep saying this and people keep correcting you.XSX, PS5, AMD cards are all packing big VRAM.
Smart decision. Its clear they've spoken to developers and everyone has said 16 is the most they'll use. Packing more and passing the cost onto us is stupid.
Lets remmeber the 3090 is a titan GPU, not a gaming GPU, in design hence the gigantic VRAM.
Once the review sites online and on youtube get hold of the cards and test them in real world situation that will be the true testing ground.
when using the new cards with last gen AMD CPUS or Intel CPUS, performance might not look so hot, tons of speculation to be had out of todays AMD presentation for sure...but as always, time will tell.
PLUS do the cards need PCIE 4.0 motherboards to get the best out of the cards?
Are the AMD figures totally skewed towards having the latest AMD tech !!!.
The problem is everything is getting faster but also noticeably more expensive too. OTH,it does make the consoles look really decent value. I suppose AMD wins either way!![]()
ye but not worked on nv YET and was used by AMDAmpere has the same - both are using a version of MS Directstorage.
NVIDIA high end GPUs like the 3080 will have worst textures than the digital PS5 which is like half its price in 2 years time lol.
How is that nonsense?Grade A nonsense.
AMD are offering you a gaming eco system with Ryzen, RDNA2 and obvious compatibabilty with the consoles.
With NV you get a GPU - if you can find one...
