Good result you got there with the 5700xt.Only just started playing this but think I'm going to enjoy it, certainly fun visiting places I know really well in London.
I'm using the HUB quality settings & pretty happy with performance (cut-scenes & driving not so much).
*this is 1440p though
So basically, the zen 2 based console CPUs will be around 20% slower than equivalent zen 3 desktop CPUs?
Ok muon, opinionated much! Clearly dont play many modern strategy games like total war warhammer II. Yes, there are games that require heavy cpu calculations and it cant be magicked away. Thats why we (ideally) need decent multithreading implemented in the latest game engines.
Please all - refund poorly optimized games. Don't just accept them for what they are.
Settings are there for you to turn down, not up. The starting point is maximum everything, then tweak downwards to suit.![]()
I got 60fps fairly consistently out of it with Raytracing set to high and DLSS set to balanced. I also knocked down shadows from Ultra to Very High, everything else left to max.
The reflections and stuff look great but I have to say I think the character models are pretty poor, and the cars are shocking....
3800x and MSI 3080
Set shadows to high instead of ultra, insane performance boost and you can't see the difference
Game looks great at 4K with Raytracing on
“I don’t care if you cannot see the difference, you should not need to turn down settings on a brand new flagship card!”
“There must be a difference otherwise the devs would not put the option there!”
“10gb is not enough!”
is that vanila?This might just be the first true 4K game in terms of texture work & geometry detail. Gorgeous.
