- 9 Nov 2005
- Southampton, hopefully not too hot, or too cold
As I'm bored at the moment, I'm doing a test tonight where I've put my Assioma pedal PWM on my Wattbike to see how things compare. I've never been able to run two PWMs together, so I'll do my own Rainmaker/LlamaLab test
Hopefully it'll confirm that my Wattbike isn't overreading!!
Sticky at Zwiftpower had lots of issues to fix from riders with Wattbikes in races before Zwift took over Zwiftpower a month or so ago, apparently.
There's a dual power source "analysis" tool on Zwiftpower as a link from your profile if you're registered there, I used it a couple of times before the summer, to see how my Direto compared to my 4iiii crank pm after I replaced the turbo belt. The Direto was ~6% higher over 20mins when I believe you would normally expect it to be ~3% lower due to drivetrain losses, but then the 4iiii is left leg only (I'm right legged and handed) and I've no idea if I have a significant power imbalance.
