Watchdogs at 4K
You can run pretty much every game on 4K with just 8GB VRAM. But you need to compromise and switch off any VRAM hogging options in this case.
Its one of the first games that seems to be designed to be played at 4K (in my opinion). And therefore, a good time to consider upgrading to a 4K capable GPU, but only if you can get a good price - The AIB models with 10% overclocks are often far too expensive and offer diminishing returns.
The RX 6800 seems like a good option, if only it was a bit cheaper - If AMD made a 8-10GB VRAM version I think it would trash the RTX 3070.
NV could be very competitive if they released a RTX 3070 TI, based on the GA102 die used in the RTX 3080/3090.
This is what I was getting when I maxed out everything at 4K
Minimum FPS: 33.27
Average FPS: 59.93
Maximum FPS: 86.63
1%% low FPS 53.80
0.1%% low FPS 43.06
Frames rendered: 5367
Operating System Windows 10 2009 19042.572
CPU: AMD Ryzen 9 3950X 16-Core Processor
GPU: NVIDIA GeForce RTX 3090
GPU Driver Version: 457.9
RAM: 31.95
VRAM: 23.78
Minimum FPS: 33.27
Average FPS: 59.93
Maximum FPS: 86.63
1%% low FPS 53.80
0.1%% low FPS 43.06
RAM: 31.95
VRAM: 23.78
What DLSS setting or if not what res?
Resolution 3840x2160
Texture Resolution Ultra
Shadows Ultra
Reflections Ultra
Post-Process Anti-Aliasing
Extra Details 100 %
Ray Traced Reflections Ultra
DLSS Ultra Performance
Temporal Upscaling 100 %
Subsurface Scattering High
Ambient Occlusion On
Field of View 70
Geometry Ultra
Environment Ultra
Texture Filtering Ultra
Headlight Shadows 4 cars
Depth Of Field On
Motion Blur On
Bloom On
V-Sync Normal
FPS Limit Off
Looks like the 5600X is gonna be a beast for gaming (to the surprise of no one :)), single threaded CPU Z score here:
https://valid.x86.fr/bench/rsf5p1/1
With a 10 or 20% overclock, it would be a potent upgrade for games optimized for 6 cores (although more cores maybe be beneficial in some games / workloads).
CPUs in the AM5 based Ryzen 6000 series (likely coming 2021 q3/q4) will probably be able to score 800 points or more in the CPU z single threaded benchmark, if overclocked.
That would be close to double the score of a lot of older Haswell era CPUs.
and that is about Watchdogs how :confused:
^ Watchdogs Legion (WD 3) and other intensive games benefit from a very fast hexacore CPU, you've correctly observed a slight tangent away from WD legions :D
Looks like Intel's 10nm CPUs could pull ahead of the 5600X in single core performance, based on their Tiger Lake laptop CPUs (top 2):
none of which you mentioned. Do have links to benchmarks showing this 'benefit from very fast hexacore' vs say a normal hexacore, in this game which is GPU bound at 4K which this thread is about?
