wtf 36fps on a 3080...The game runs smooth with Gsync for me at 4k everything maxed RT & DLSS, 36-50fps.
However this actually seems below what I should be getting for my rig (3700x & 3080).
Nope, thats about what you should expect. Everything else is/was pure marketing. Consider yourself marketed!The game runs smooth with Gsync for me at 4k everything maxed RT & DLSS, 36-50fps.
This is what I was getting when I maxed out everything at 4K
Minimum FPS: 33.27
Average FPS: 59.93
Maximum FPS: 86.63
1%% low FPS 53.80
0.1%% low FPS 43.06
Frames rendered: 5367
Operating System Windows 10 2009 19042.572
CPU: AMD Ryzen 9 3950X 16-Core Processor
GPU: NVIDIA GeForce RTX 3090
GPU Driver Version: 457.9
RAM: 31.95
VRAM: 23.78
What DLSS setting or if not what res?
Yup. Don't think it would get mods anyway.is that vanila?
End of the first sentence. 4K.
Now do do AMD that drops to 5fps in shadow of the tomb Raider can't wait to see watch dogs legion![]()
Hence why it will be crashing for the first 6months until the sort out the drivers.![]()
Billy Goats gruffWhat DLSS setting or if not what res?
), single threaded CPU Z score here:and that is about Watchdogs howLooks like the 5600X is gonna be a beast for gaming (to the surprise of no one), single threaded CPU Z score here:
https://valid.x86.fr/bench/rsf5p1/1
With a 10 or 20% overclock, it would be a potent upgrade for games optimized for 6 cores (although more cores maybe be beneficial in some games / workloads).
CPUs in the AM5 based Ryzen 6000 series (likely coming 2021 q3/q4) will probably be able to score 800 points or more in the CPU z single threaded benchmark, if overclocked.
That would be close to double the score of a lot of older Haswell era CPUs.
none of which you mentioned. Do have links to benchmarks showing this 'benefit from very fast hexacore' vs say a normal hexacore, in this game which is GPU bound at 4K which this thread is about?^ Watchdogs Legion (WD 3) and other intensive games benefit from a very fast hexacore CPU, you've correctly observed a slight tangent away from WD legions![]()
