Yep that's all I did.
These chips look a lot more skookum than AMD let on.
What game settings were you using out of interest?
Had to google that word. Yeah I'm quite happy with it. I might get rid of my 3700x in favour of it.These chips look a lot more skookum than AMD let on.
Thank you! Enjoy it.Mostly high I can't remember them all but I can check tomorrow.
It's also 1000 points better on firestrike than the 3700x
Ive also installed a 5600X today and done a few tests.
I was running a Ryzen 3600, 32GB 3200 ballistix and a RTX 3080
i only upgraded to a Ryzen 3600 2 weeks ago so not had chance to compare much.
Ive seen a some maybe 2-5% fps increase in a few games, Horizonal Zero dawn seemed to go up 10% but was already amazing on the Ryzen 3600.
A fully modded Fallout4 with enb, still dipped into the 50'fps when looking in the same direction as the 3600, that was my main test as my late i7 3770K was in the 30's. Buit I think that engine isnt the best.
Benchmarks show a nice 14-19% increase.
So, overall I am happy with that cheap upgrade from the 2nd hand 3600. The increase means im futureproof for a bit.
But for gaming, its not going to be much different at higher resolutions.
Im happy for the price I paid, but for a 30% RRP increase over a current Ryzen 3600 im not sure.
I certainly wouldn't bother. The 3600 is still a great chip - maybe wait a few months as we should be seeing some more interesting/better value 5000 parts then.Hey, I've just spent a little time searching for the answer and I can't find any threads, is it going to be worth upgrading from a 3600 to a 5600x or 5800x? Will the 5600x be a single CCX like the 3300x? I have managed to find from my search that the 5800x will be a single CCX.
What resolution?
What resolution are you playing at? Maybe GPU bound? I'm very impressed with the performance.
3440x1440
https://i.~ibb.co~/mb7KDBQ/received-835066627282042.jpgJust do what I've done and push your 3600 as far as it can go, a lot of games still rely on mhz and I've loaded in several titles quicker than somebody with a 3950.
We don't know the full gains yet so wait and see.
That's just with pbo enabled I might try to push it close to the 5ghz mark later today.
https://~ibb.co~/gmC8j7s
Then those performance gains are very good. You are gpu bottlenecked but still saw good cpu improvements - great cpu from amd
