Quest 2 accessories - recommendations, reviews etc
5 Mar 2007
Macclesfield
That's playing quest 2 games, using it as a charging cable right? Rather than PCVR?
I've used it for both (to just charge and PCVR). However, as I've now got remote desktop working well I only use the cable to charge, it charges whilst playing, slowly but still charges and if not using the Quest 2 it charges it ~1.5 hours.
18 Oct 2002
Mars
The MVHStudio strap is very good indeed, really comfy with the battery pack holder built in.
You can even remove the faceplate for a wider FOV as its not needed due to the forehead strap.
Caporegime
20 Oct 2004
I think I'll grab one when they come back in stock. How easy is it to change for a different user?
16 Jul 2010
Can somebody advise what cable i need in order to use the quest 2 with the PC? are you also able to use steam games?
A USB2 cable will work, but a USB3 cable is preferred.
The big issues that the normal limit for USB3 cable length is about 3m which isn't long enough for a lot of games. There are longer cables but they tend to be more expensive.
And yes you can play both PC Oculus and Steam games using a USB cable.
There's also Virtual Desktop which allows you to play PC VR games wirelessly, but requires setting up a developer account and sideloading. Plus the results are highly variable depending on your WiFi setup.
29 Jun 2016
Up Norf
Cheers for the reply, is there a preferred/tried and tested cable?
17 Apr 2009
There's now a wait list up on the MVHStudios site for the headstrap. Price has also gone up by a tenner (not a huge shocker though, to be fair - it was priced too low to begin with).
OP
18 Jun 2018
Isle of Wight
He commented when he first posted it up on Reddit that after expenses, he didn't actually make very much on each item, and he did them more as a hobby. I guess given the amount of orders coming in, he's trying to actually earn from his time spent (and the time that the 3d printers are running for).
19 Dec 2010
Thanks for the heads up. Just joined the waiting list.
Currently #55 out of 55.
Waiting list for everything these days.
20 Apr 2015
3 Jan 2010
Hailsham
Thanks, got myself on the list 72nd
Bit annoying as I had emailed him about the headstrap and hadn't got a response. Hopefully they don't take to long to get
