*** The Official OCUK Cinebench R20 benchmark Thread ***
Okay so first run with only XMP enabled.
I aint going to do multi thread, a bit pointless when I have half the cores of a 5950X + Dark Hero lol
I did some RAM tuning and got latency down to 53.6ns so far.
Good result on the ram latency. Nice to see gains there.
I was getting around 63.7ns on my 3800X so its a nice improvement. This is at 3800Mhz, I am yet to try 4000Mhz but that depends on BIOS + there is not a lot of information about it so far. I would also have to run tests to make my 3600Mhz C16 kit run at 4000Mhz.
4000Mhz might be possible with the 8 pack ram, some forum members have managed to hit them speeds.
I have an 8 Pack kit too, Im just not sure about all the timings for this specific kit, AND I only have a 5800X to test which can be a hit or miss at 4000Mhz since I dont think they are guaranteed to be able to hit it 2000Mhz FCLK.
Updated.
@Nightmare you were the first to break 625 Single-Threaded points so you get in the honourable mentions list, congrats :)
Next target 650 points
Is that just boosting to 4.95? is it still stock?
You're 2% short of 650, at 5.1Ghz it would do it, i would imagine that's not going to be easy but someone will do it.
Updated your score :)
I only pressed the Auto OC button on Ryzen Master which supposely turns on PBO. I know its better to do it on the BIOS but its late to look at proper values. I did it to see if it did anything and got 100Mhz more. Did that 1 run and turned it off, I'll investigate it further tomorrow.
Thank's, i've changed it to PBO, to keep it accurate :)
