How can I soften my onscreen image for gaming
26 Sep 2020
Ive turned monitor sharpness to zero.
I have an Nvidia 2080 Super.
Id like to add additional softness to my gaming experience, but havent been able to do so. Is there a way to soften the image?
(On a seperate note, Im finding WRC 9 much, much sharper than the lovely soft image in dirt 2.0. Turning sharpening off and motion blur on in WRC 9 does not give me a nice soft image, however).
Can anyone help with the first (or both) issues?
Permabanned
28 Nov 2006
N Ireland
Any reason why you want to go the opposite of everyone else? Is this due to the sparkling pixelated effect called aliasing? That can be fixed.
You could run a non native resolution also, If the game has a slider lower it below 100%? Im curious as to why blurry softness is what you want.
10 Jan 2007
Warwickshire
confused too, thats why i did not bother replying
OP
26 Sep 2020
Ive turned all jaggies smoothening options to max. After a return to PC gaming (from many years of console gaming) Im not used to the ultra sharpness of the PC monitor (VG27AQ) and rather prefer the softness of my TV with sharpness set to virtually 0. Feels more film like, real, less looks less computer generated. I like that look.
I did find some setting in a Nvidia control panel somewhere a few months ago (device manager settings maybe) but was totally unable to change and save it. Gave up trying. Felt like the setting was locked and I couldnt find a way to override sharpening, although the option appeared to be there. I should look for that setting again so I can reference it.
Ive tried running games in windowed mode at a non native resolution, and the added smoothness is minimal.
Ive only got one game which has a setting that allows you to render at 90% of the native 1440 resolution. A few which offer 75% rendering which is a little too soft, but not too bad either.
Be nice to find out if I can find a way to address the cards capability to soften images, all the time. I have no idea whether that is possible.
OP
26 Sep 2020
Ive had another look. It was in the Nvidia Control Panel that I was looking for an override sharpness feature, which I remember thinking I found, but I was unable to make the image softer and save it.
Under Manage 3D Settings > Global Settings > Image Sharpening
I wanted to enable GPU scaling and slide the slider down to 0.
This may be the same as OFF, which was the default. In which case it wouldnt make any difference.
I couldnt experiment as any attempt to apply changes resulted in the message
Access Denied. Failed to apply selected settings to your system.
I assumed a few people might know how to get a graphics card to soften images, but I also thought that it might not be possible to make images softer, I was being hopeful.
24 Oct 2005
North East
fxaa blurs the image a little. You can maybe turn the res down a notch that could soften the image. Lower texture setting a notch might help, soften the sharp textures?
iu
Maybe adjust the slider to the negative may do it?
OP
26 Sep 2020
iu
- Turning FXAA On and clicking apply results in the message I mentioned: "
Access Denied. Failed to apply selected settings to your system."
- Experimenting with non native resolutions already, thanks for the suggestion.
- Prefer high res textures. Just a softer image.
If youve got a decent TV, crank the sharpness up to max, then down to minimum.
There is a wide range of pixel sharpness, which is a user preference thing.
My monitor has SHARPNESS and VIVID PIXEL, two "pixel sharpness" technologies, which have nothing to do with resolution, pixel density, texture clarity, but rather affect pixel sharpness.
The half dozen anti aliasing technologies, each with different benefits, GPU demands, performance etc... every game ive owned has settings for anti aliasing methods in-game.
I just find some games are far more sharp than others, hence looking to see what can be done with settings outside of games.
Right now, I cant edit 3D settings, I get that error message I mentioned.
OP
26 Sep 2020
I suspect its Anisotropic filtering which can soften the crispness of textures, that I want to control via the NVidia control panel, as the default setting is APPLICATION CONTROLLED, and id like instead to set it to override at 16x, which is an option.
I can change the setting to 16x to see what happens, but I get the following message (again) when I click apply:
Access denied
4 Aug 2006
Mip bias was often configurable within games, which could 'blur' of soften some edge textures. But I don't recall seeing the option in games for some time.
6 Oct 2004
Birmingham
This won't do anything, your screen will still display at native resolution, it's just that the window will take up less of it.
You need non-native and fullscreen (e.g. run at 1080p on a 1440p monitor). That way your monitor will have to interpolate the missing pixels and hopefully make it a blurry mess nice and soft
OP
26 Sep 2020
Interesting.
I tried this, and the image became so soft I could insert my head through the monitor. But during the event, the monitor suctioned half my intelligence out of my head, and Im all thats left :(
OP
26 Sep 2020
Get a cloth and smear some Vaseline on your screen.
I will try this method with something I like the smell of, so bacon fat, or maybe I cant believe its not butter, which should be translucent at screen temperature. If you come round to play, I'll let you lick the screen if its too blurry for you.
27 Jul 2004
Yancashire
Interesting.
It's a strange request to soften an image for gaming(!) but it seems like you have a specific need as the obvious solution suggested of running a lower non native res obviously doesn't float your boat.
If you're really serious about doing it you should look into reshade. An absolute ton of filters to experiment with but my suggestion to you would be to try various settings of Gaussian blur and de-sharpening. Reshade is superb and with a lot of time and effort you can get games looking just how you want. I use it a lot, if you've never used it before it's like Lightroom (photography editing prog) for motion (games).
11 Oct 2005
Set the resolution to a lower setting than your monitor's native one.
e.g.
If you have a 1440p monitor, set the game to 1080p.
