I'm considering the Samsung T5 1tb but haven't pulled the trigger yet ...You got a recommendation for the USB SSD?
I havent done that since I was a child, not sure trading in my game to game uk for a 5th of its value and buying a used game for 5% cheaper than brand new is a good deal. Although probably a bit better doing it on something like ebay.
I can use it for backup of PS5 games as well if required.
The consoles sent out for review don't let you do this, I'm hoping a day 1 patch will enable it.
My Internet is decent enough that I can just download something when I want it.
I've never seen the release of a new gen be so bogged down with what BC is doing.
I'm guessing it's because MS have gone in on BC (they don't seem to have much else to show at the moment!) And Sony have got it but it isn't the headline feature?
I'm on 200 meg because I can't be bothered to upgrade it, it's quick anyway and definitely quick enough for what I need. But I more often than not found download speeds on my PS4 to be awful.
Presumably the PS5 will let you have multiple extended storage devices?
Not plugged in at the same time, but 1 plugged in at a time, swapping between them - does it allow that?The PS4 lets you only connect one at a time. The backend to PS5 seems almost identical, looking at the settings available in the UI. So you can't use an external SSD and an external USB HDD simultaneously - that's my prediction.
Only issue there would be you'd need to plug in the storage HDD to run updates every few weeks/months.
Yeah one at a time would work. But what a faff! Personally, I'd just have one massive USB HDD as storage as then use the internal SSD for playing from, with a second internal SSD when they become available.
Can't see many people having this issue tbh! If someone is filling a 1TB drive with PS4 games, and the 667GB with PS5 games, good on them!!
