Your radiator is installed wrong way round man. The inlets and outlets should be at the at the top to assist water flow amd maximise radiator flow.So my Overclockers 2:39pm order of 5900X has arrived yesterday(despite not having paid for Saturday delivery, thanks DPD!). I think the reason why an order placed so late shipped so quickly is that I used paypal balance to pay, so it authorized instantly.
The machine is an absolute beast, tried some games and video conversion with handbrake, converting a 2h clip on my old 4790K used to average ~100fps, the new Ryzen averages 520fps. Incredible.
Nearly had a heart attack though, as I installed everything and the board wouldn't boot up, with the "CPU" led permanently on, indicating either a missing or faulty CPU. Flashed the board with the previous version of BIOS(v13 not v14, but still with the new AGESA) and it worked.
I love that view in the task manager
You radiator is installed wrong way round man. The inlets and outlets should be at the at the top to assist water flow amd maximise radiator flow.
Really? Is that the go to position these days?Nope.
He has since done a follow up to this video due to all of the panic the original caused (myself included haha).Yeah:
It won't be critical by any means but tubes down is probably best.
Apparently they all do. Most have somewhere around 90% liquid level according to Gamers Nexus on YTIs there any reason why AIO would have that much air in the system?
Exactly, I watched this exact video before installation. Without it I would have ran the tubes to the top since yeah, it seems more intutive, but tubes are meant to be down so that any air in the system stays at the top of the radiator, not near the tube inlet/outlet and isn't then sucked into the cpu pump.Yeah:
from a hydro pressure point of view to push water against mavity is gonna be harder work tmr or the pump thank allowing mavity to assist water flow.
Interesting. When my 100i dies I must remember to open it and drain the fluid see what it is...I would have though they would have filled those system under pressure.Apparently they all do. Most have somewhere around 90% liquid level according to Gamers Nexus on YT
5900x now only £559.99.
Price has been overclocked for your convenience![]()
An 11% increase over RRP is ridiculous.
You won't know unless you make an order. You can always cancel it if it's too high for your likingWhat is the current queues for 5600x and 5800x?
but I am keeping an eye on here and competitor, the first one putting an ETA will get the money else can easily wait 2 months.
