Is that 102 Celsius of Fahrenheit?
If Celsius, what custom loop are you running
102 degrees celsius on a custom 360mm waerloop setup, it only hits that for a split second at 4.7ghz and backs off to the mid 70's
I guess that's not water then, cos physics? What are you using? Sorry for noob questions but I'm new to this stuff102 degrees celsius on a custom 360mm waerloop setup, it only hits that for a split second at 4.7ghz and backs off to the mid 70's
.I guess that's not water then, cos physics? What are you using? Sorry for noob questions but I'm new to this stuff.
??? i run custom watercooling a ek magnitude amd cpu block and a ek pe classic 45mm thick 360mm radiator, but even then at 4.7ghz all core the chip does run hot.
this is my current setup
Just out of interest, have you tried second jet plate included with magnitude in the box? Few reviews I saw mentioned it reduced temps by few degrees. Just wonder
Cool, my question was more to block rather than related to the topic or pointing the reason for high tempsi didnt i used the 0.5mm thick plate that was already installed in the block, dont get me wrong at stock the 5950x is a diffrent beast never breaking 60 degrees under heavy load, but a all core oc and thing do get a bit toasty, most reviews said that when they oc'd the 5950x and i'm seeing the same but only when overclokced all core
Cool, my question was more to block rather than related to the topic or pointing the reason for high temps![]()
From tests better is the one in the box 0.6, which is unfortunate as EK claims installed is the best ( I think manual even says that).oh whoops, being the block is am4 only i asume the best jet plate is already installed, likewise for the intel version, or am i wrong?
Here for example (especially better if you prefer slower pump speed).
https://www.guru3d.com/articles-pages/choosing-the-optmal-zen2-ek-waterblock-review,9.html
I think Gibbo said that your position will be emailed every friday or when they have a delivery.
Here's what I would do if I were in your shoes:I haven’t had an email regarding me queue position yet, i ordered my processor thursday night. Does anybody know why that is?
Also no money has been taken from my bank account yet, but when i pre ordered my RTX 3080 from overclockers they took money out on the same day so surely they should do the same for zen 2.
Should i cancel This pre order and re-order?
I have only just ordered my 5900x on fri night i think. I havent had an email yet and order is still being processed for payment , this is taking much longer than usual. I would just wait as long as you can see the order in your online account.I haven’t had an email regarding me queue position yet, i ordered my processor thursday night. Does anybody know why that is?
Should i cancel This pre order and reorder?
Yeah the order is showing up on my Overclockers account so i will just wait and hope i get an email soon about my position. However there is literally nothing in my bank statements regarding my processor. Its not even being processed.I have only just ordered my 5900x on fri night i think. I havent had an email yet and order is still being processed for payment , this is taking much longer than usual. I would just wait as long as you can see the order in your online account.
Interesting:
Would these Crucial Ballistix BL2K8G36C16U4B 3600 MHz (8GB x4) work paired with a 5900X I have on order with OverclockersUK?Performance is lost by going above or below 4 ranks of memory (4x single sided or 2x double sided sticks).
Ideally you'd want 4000Mhz for a 1:1 divider between memory and infinity fabric.
Inb4 mad rush for micron memory with their 2gb chips and single sided ram and abandoning the samsung b die 1gb chips and double sided ram ship.
