- 24 May 2011
Scoreboard updated.
Sorry my clocks are wrong.. apparently 1950 boost clock!
Scoreboard updated.
	Nice score, which card do you have? Some aftermarket cards with the better heatsinks do manage to get or maintain higher boosts.8700K@5GHz
3800@ 1860/5000
Driver 457.09
 Nearly 8 weeks old and still going strong.
 Nearly 8 weeks old and still going strong.Heh, crappy Zotac, urh!That crap Zotac one, or so people tell meNearly 8 weeks old and still going strong.
According to gpuz boosts 2000-2050
By the way Kaaps, his will have boosted to 2050 at least like mine. No way he got that score on 1860, that is just what GPU-Z saysScoreboard updated.
That's why I quoted what he said about boosting to 2000-2050I can only work with the figures people post.
But to answer your point, I also thought the actual boost was about 2050.
Boost limit can change from run to run as isn't it just based off power and temp.That's why I quoted what he said about boosting to 2000-2050
Maybe he can clarify. Not that it is a big deal
Yeah, I do get slightly different scores when rerunning benches, but don’t have the patience to run long benchmarks more than once couple of times if doing loads like I did recently. Going to install this bench again and have another crack at it however as I am done with other beaches for nowBoost limit can change from run to run as isn't it just based off power and temp.
To the other thing you asked AFIAK it was 500 on mem to get it to 1250 and then 75 on the core and let boost do it's work.
Won't be on the PC for the next few days to check since playing Spidey MM on thr PS4.
