Can you expand on dmc comment?2 freezes so far on Gears Tactics. Can be annoying when a level takes a while. Hopefully some needed software updates soon.
Wonder if the tiny performance advantage at 4K and getting trashed by the PS5 in 120 FPS mode in Devil may cry is game related or drivers![]()
@chrcoluk mine doesn't have that issue so I would say you have a faulty unit. Assume you've tried the usual like swapping HDMI ports/cables and factory reset of TV and console?
If they weren't using high speed SSD tech they probably would have gone 2tb but 2tb in SSD tech there using would have just increased the cost far too much although I agree more space is neededI've Installed Warzone, Cold War, FH4 & F1. Over 50% of HDD space gone already. Storage is the big issue this generation. I feel maybe we should have got 2TB as standard
Yeah but to cover yourself do what I did and use the online chat for confirmation. At the beginning of the chat the advisor did say I had to buy the insurance at the same time as the product, but once I pointed out that term I highlighted in my first post the advisor read it himself and confirmed I could buy insurance after buying the product (as long as its been within 30 days). After that I just bought the insurance.
Question
With my One X and Sonos Playbar I was able to get 5 1 from optical cable to TV and HDMI from TV to Xbox.
If appears the Xbox series x doesn't recognise it?
No the initial return would use the standard 12 month warranty.I noticed it only allows 1 console swap, so if you e.g. return in the first week with a manufacturing fault, the extended coverage is gone?
Working fine here. There were a few more options on the Xbox side then my original One had so make sure they are set correctly.
(at this rate I'll just pick up the digital version and will return the physical disk when it arrives).I have the 1tb expansion drive although in all honesty it’s not really needed. A decent Sata usb ssd will work great for non X games. Saying that it’s fun copying games from internal to the 1tb expansion it’s stupidly quick......
