Decent water-based satin coat?
24 Oct 2014
South coast
After a couple of bad experiences with water-based wood paint, most recently the doorframe and skirting boards in my parent's kitchen (Leyland paint), I bought some Albany Oil Based Satin to redo my guest bedroom.
My problem with the water based paints was I found they didn't flow well, and dried with brush strokes visible and slightly ridged.
The oil based satin has given a good finish and there are no brushmarks visible, but I'd forgotten how much I hate the smell of paint and white spirit throughout the house.
Is a decent water-based satinwood available? Or is it a matter of technique to get a good, back-of-mirror finish with water-based paints?
I use some floetrol with water based , it helps but still never as good as oil based
the trick I find with water based is to slap it on quickly , don’t layer too thin and don’t go back over it except to lay it off a little with damp clean brush
it’s tedious but at Least when you make a mess you can quickly wash it off with a damp rag before it dries
As someone who has used oil based gloss for many years I have finally switched to Dulux Satinwood. I use a mini roller and a brush for the bits that can't reach with the roller. I do 2 thin coats being careful of brush marks and they look pretty decent. I'm enjoying being able to re-coat after a few hours (rather than the next day) and not stinking the house out. The finish also looks good too and I can clean up the rollers/brushes with soapy water.
Dave
Basically, oil paints always flow better. For water based wood paints don't skimp - the cheaper ones are generally awful.
They all go yellow, virutally no difference there.
I've just got some johnstones aquaguard in satin white. Reviews have suggested you can get away with no primer/undercoat, and a one coat on a small area to test (on old gloss work so probably oil based) has come up well - did a scratch test with the keys and impressed with the result.
I think scuff-x seems to be a favourite in the decorating community but highly priced
JBuk is right. The application of water based gloss or satin is completely different to oil based paints. You have to be extremely fast. It's takes a fair bit of practice to "slap" the paint on without putting on too much but you really haven't got any time to mess about. But having said that I find all water based don't give a very durable finish anyway. If you want durable then it is better to just paint it with emulsion and then put a coat of decorators varnish on the top. Much easier to get a great finish and is much tougher too.
