Is that using a native ARM version or is it using Rosetta 2?
ARM version, on battery!
That is a really beautiful piece of data. What is striking to me is the better branch prediction of the A12 over the 9900k, which wobbles about but probably accounts for a lot of those ~10% extra cycles.
Could that be because RISC has less possible branch prediction routes that it can go down, so with less options to choose from, it automatically becomes better at prediciton. ? By that I mean, does the ARM approach with a RISC instruction set simply have a lower number of possible next instructions compared to and x86 CISC approach ? ( I genuinely dont know )
I.e.
If ARM has an average of 5 possible branch choices, and x86 has 6 branch choices ... by the law of averages, the ARM will better it'll have a 20% chance of being right (at complete random choice) versus 16% for x86. ?
The architecture is built around an ISA so I imagine there must be room for some differences?Branch choices are determined by the code that's running, ISA is not that relevant here. It's about microarchitecture.
M1 MacBook Pro Is Faster Than a 2019 iMac Pro With Vega 56 GPU, 128GB RAM in Final Cut Pro X Video Exporting Tests
https://wccftech.com/m1-macbook-pro-faster-than-imac-pro-final-cut-pro-x-video-exporting-test/
Shocker as M1 using Hardware acceleration beats Xeon not using Hardware acceleration![]()
m1 apu makes amd and Intel offerings look pathetic, amd need to up their apu game.
@HACO Have they got performance per watt comparisons where all tested CPUs are at equal watts, so we can see watt-watt?
No Bootcamp, no VMware Fusion (yet), no external GPU support, two fewer TB3 ports, RAM limited to 16GB on the current models to name a few.I'm looking at this and I can't help but look for the flaw. There's no such thing as a free lunch, and I'm looking for the trade off. Anyone got any ideas where it might be?
