Pc crashed, no display now.
Have you tried a different monitor?
Tried 1 stick of ram at a time?
Tried the bios flashback?
tried stripping the whole lot down and rebuilding outside the case?
Not tried a different monitor as other devices work fine with monitor.
I do have another monitor to test.
Yea tried 1 stick of ram.
In the process of getting a friend to do me a usb so I can try the bios flash back.
Not done a rebuild outside of the case.
Your PSU most likely to be the problem. There is no issue with the bios as it was working previously. The bios wouldn’t just randomly get broken because a crash.
you cleared Cmos and all that?
Yea cleared CMos, don't have a spare PSU to test.
dont flash bios if the PSU got problems you risk corrupting the board. get a new PSU to test or borrow one as above.
You say that - but it sounds like he has bios flashback via USB on the board, so would still be able to overflash if worst came to worst.
Not suggesting its a good idea - but could avoid buying another PSU for no need.
hope he hasnt. but if he has, then haha...
Ok got home took out the Mrs PSU that works fine and still exactly the same... Boots, no display and boot light on, on the mobo.
Sometimes when I boot, the boot light doesn't come on and still won't post.
the board has debug light what is that telling you?
maybe something on the mobo broken, but you said it boots....you mean it turns on and boots into windows?
Sry my bad it doesn't boot to Windows, the computer turns on all RGB turn on and all fans spinning... No debug lights on... Monitor displays no signal. Even if I remove all ssds it's still the same, I don't even get to go into bios.
Maybe someone broke in the board. If all the Gpu, psu and ram tested. Possibly a surge or something broken parts of the motherboard. Checked all the connection are seated properly?
start RMA process with MSI and AMD. You can’t use the machine in the meantime, so might as well send CPU and Board off for replacement. I think AMD is very quick in returning processors MSI might take a little longer.
Yea removed everything and reseated, reconnected everything.
Thank a lot to everyone who has helped.
Have you tried to repair the windows install? I had a similar problem yesterday, got a new monitor and was playing around with the refresh rate and swapping between the old and new monitor. Switched it off the computer to use just the new monitor and it wouldn't display even if I swapped between hdmi and displayport. Had to turn off the computer, restart with just the new one on displayport and it came on went into nvidia control panel and switch the old monitor on from there. It seems it didn't like both displays being on or it forgot which one it was supposed to use so didn't use either. Anyway it's just a thought.
I said it was just a thought, I had no signal on both monitors, no bios logo and neither of the monitors would show their menus or turn off.
