For me everything goes through my SoundBlaster X7 which is mainly gaming.
Yesterday ordered a Fiio K5 Pro, which if all goes well will replace the Soundblaster X7.
The news that the consoles are a step backwards for audio (XSX; no USB audio support, PS5; same as PS4 with no Tempest 3D audio over HDMI) means that I want to rethink my setup. The X7 was a fantastic device for unifying all my boxes and getting VSS. But even with it, lately I've found myself using Dolby Atmos for headphone more on Xbox, and Sony's Platinum's for convenience. So I want something that provides better stereo clarity. I know the K5 Pro might be a small bump but it means I'll be able to get rid of my Optical switcher eventually too.
Any more updates @Timber ?![]()
I was looking for a new pair of headphones, am planning on picking up a soundblaster G6 and was looking for some closed headphones to go with it. Already have a pair of HD 599's which im planning on keeping for now. I was thinking of DT 770s or DT 880s but is there anything else worth considering?
DT770.I was looking for a new pair of headphones, am planning on picking up a soundblaster G6 and was looking for some closed headphones to go with it. Already have a pair of HD 599's which im planning on keeping for now. I was thinking of DT 770s or DT 880s but is there anything else worth considering?
The Fiio K3 amp/dac does not work via USB on the PS5.![]()
Yeah I tried that too, and both front and rear ports, no luck. The K3 didn't work on the PS4 either, so wasn't holding out too much hope that it would.What about if you put the K3 in USB 1.0 mode?
The PS5 only works with USB Audio Class 1 devices (same as the PS4) but Creative DAC/AMPs like the G3 and G6 have been confirmed to work. Also the Fiio E10K as well.
I've also read that the PS5 doesn't have the low volume over USB issue that PS4 did.
Got a space waiting on a decent wireless headset but there's alack of info around what functions work and don't work with the PS4/5.
I had an order for the Pulse 3D headset but they were out of stock, so that's been cancelled - if I can get find a set in stock I'll probably give them a try - the integration with features (fully working chatmix and volume) and a pretty decent price and big plus points. Issue being they're like hens teeth at the moment... Hence looking into other options.In terms of wireless headset thoughts:
- Steelseries 7X seems to be the darling of Resetera atm. Even though it's the Xbox variant it has a switch on the dongle to choose Xbox or PC/PS and is confirmed working with 3D audio on PS5. That said at £160 it is very pricey imo. I'd probably just jump up to a Audeze Penrose at that amount. If you're purely a PS5 player then the Arctis 7P will do and probably has chat volume support. The 7X seems to be hard to get atm.
- Steelseries 1 Wireless Xbox - Cheaper version of the above, will work with anything.
- Sony 3D Pulse - not ideal but probably the cheapest Wireless headset for PS5. Likely Sony are basing their HRTF/3D profiles on these and I'd imagine there are OK for gaming. The integration of the Sony headsets is nice too. I just bought the Platinums for the few 3D games on PS4 but have found myself using them out of convenience even thought I have nicer headphones around.
How do you find the Platinums compared to the DT990 pro?
