I managed to grab a new £209 inc delivery sabrent rocket 4.0 2T from an auction site - still waiting on that 5950x though >,<
I was looking at that too, but I was concerned that I might not be able to check that it works because I'm waiting on a 5900x... didn't want a nasty surprise in January and no warranty cover.
I was able to register the serial with sabrent for my 5 year extended warranty
I strongly recommend you to purchase our products from authorized sellers on Amazon like 1880 UK, SLM UK to mention some. This is to avoid inconveniences while trying to request a warranty replacement.
In most of cases, we're unable to validate the order with unauthorized sellers and the process cannot continue even when you have a sealed product. That's why we suggest you to look for the previous sellers.
I did contact Sabrent about buying from a private seller and they said this:
However, it is weird when you register for the warranty that ebay is one of the options you can pick. I'm sure I'm being overly paranoid, and hope you don't have any issues (if you ever need to use the warranty, or otherwise).
Happy with my 500gb 850.Rainforest has the Samsung 980 500GB in stock for a reasonable price (just shy of 140) right now so I decided to bite the bullet and order, since it only works out something like ~£20 more than a 250GB one here
Ah, WD SN850 is a touch cheaper and supposedly a better drive. Dunno if I should change over. Thoughts?
Wow the WD sn850 is amazing, smashes the 980 pro from Samsung
Gigabyte X570 I Aorus Pro WiFi
Sabrent Rocket NVMe PCIe 4.0 M.2 (2TB) in the CPU slot (on top, not underneath)
CrystalDiskMark 7.0.0 x64, default settings
There is a catch: in this motherboard I had to wait 10-30s for the drive to cool down to get peak benchmark results. Mini-ITX X570 boards really seem to suck at cooling these things during artificial stress tests, but the drive seems fine. Hovers around 50-60C idle.
Hmm, difficult to say. I've not experienced any problems but then the drive is so bloody fast. I doubt 5GB/sec down to 3GB/sec is even noticeable when loading something like Battlefield 5, or The Division 2. I only suggest you have good case airflow, as that was the biggest influencer in NVMe drive temperature.I have this.mobo. The M.2 slot has a fan on it, are you saying it's not good enough?
Hi has anyone done a raid 0 setup, I've got 1x980 Pro installed and will be getting another to raid 0 on my x570 mobo with 5900x cpu, I'm sure I read somewhere windows 10 has the raid drivers included, can anyone confirm this or is it the usual fresh install then use a USB stick to install amd raid
Fair point just want to have a go basically,I don’t see the point in running raid when these drives are so fast to begin with. Seems a bit pointless to me?
