M1 Mac vs Ryzen 7?
Food for your thought, basic computer stuff:
It's not the CPU that supports (or doesn't support) thunderbolt. There are thunderbolt controllers that you put inside a computer, they connect to the CPU via PCIe. As long as your computer has PCIe, you can add thunderbolt to it. Apple, ARM, Intel, Qualcomm, AMD, doesn't matter. I didn't feel like I needed to explain this, being on a computer forum and all, but now I know that I do.
Oh Castiel, as usual you don't understand what you're googling. Theoretical support for PCIe 4.0 doesn't have direct benefit to current M1 product lineup because current M1 product lineup at Apple doesn't come with any PCIe slots or expansion possibilities, so you won't be adding any "thunderbolt to it". I didn't think I needed to explain this, to quote your cringe/shadenfreude. It has nothing to do with arm, it's a product architecture issue, not CPU architecture issue. Exhausting. Just... exhausting interlocutor.
But why are you complaining that the current product lineup - which is entry level - doesn't have features that you want in a pro setup?
I could complain that a BMW 220d doesn't have the performance of a BMW M2. That doesn't mean that the entire architecture of the 2-series is compromised. It just means that this version of the product doesn't have the features you want and therefore is not for you.
Why are you trying to argue that this is a pro-level product and thus should have pro-level features when it is clearly a first dip in the water to show what the platform is capable of? Sure, you can use it for semi-pro level stuff but anyone who even considers a Mac Mini of any spec as a pro-grade workstation needs their head examined. That is not what it is for.
Precisely as above, doesn't matter if arm is more memory efficient for os, we are talking about very specific purpose, specific tasks and programs and they always need more memory than 16Gb.
We've discussed this before and fanboys already had their shout match with me - M1 is an interesting idea, unwelcome, not really needed, doomed to fail in the long run, but interesting. I can honestly see it working well for end user on ultra laptops and pad-ish devices, but it just doesn't scale to desktops, not for now at least.
I spent 15 years in audio visual industry and can not for the life of me imagine doing a/v work on something with such architectural compromises as M1 mac mini. It wasn't made for this type of work. More ports, more memory, more expansion, few generations from now and then we'll discuss editing and recording.
Unwelcome? Competition is a good thing not a bad thing. This is far better than intel for the same level and significantly cheaper as well.
It's probably the kick in the arse that intel need.
But why are you complaining that the current product lineup - which is entry level - doesn't have features that you want in a pro setup?.
Because previous "entry level" product lineup (wrong term, because with Apple there is no entry level and pro level, there is just for example mac mini that you can leave at basic or max out and that's it) had those features.
Generation to generation we get less. Less ports, less expansion, and now even less max memory. And I appreciate forumites not agreeing that more than 16gb is needed because "arm" but that's just powdering the obvious flaw - new processor may kick bottoms in terms of optimisations but the architectural design of this generation of apple silicon platform is limited, more limited than previous entry level Mac minis and MBPs of yesteryear. Come on, you have to see it for what it is.
But - as has been said before - these are the first products running on this new architecture.
Sure, they have fewer ports and less max memory. If this is a problem then they aren't for you. You are not their target customer. You're not being forced to buy them.
If you think about it though, the lack of ports (which, lets face it is what you seem to have the most beef with), is becoming more and more common across all laptops/computers, especially 'ultrabooks' which is what the Macbook Air is. Huawei Matebook Pro 2020 has 2 x USB-C ports and 1 x USB-A port. Dell XPS 13 has 2 x Thunderbolt and 1 x USB-C.
I understand what you are saying about the machines having less ports than previous models, but that's nothing new with Apple, nor with other manufacturers. Ports have been dwindling in quantity for years.
And when you unplug it from external monitors and take it to work, standing in presentation room, how is your keyboard and mouse and gigabit network? You still need individual ports, it's just you didn't get them within the price of the laptop this time, you had to buy them separately at premium, no?
I like most I would imagine wouldn't require or expect a wired connection to do a presentation, I also wouldn't need or want a keyboard. That leaves a display and mouse/wireless presenter at best as the two devices that I may need, which are catered for by the 2 ports available :)
For most presentations these days, at least with our meeting room, it's actually easier just to use my phone and cast it to the projector :)
When my current (Windows ) laptop actually needs to be used as a laptop then I need 1 or maybe 2 ports at most.
The rest of the time, it's so much more convenient to plug to plug in 1 cable both at home or at work, and have everything else I need.
Whichever way you look at it, Apple could have stuck another couple of ports in there for pennies. What they've done is their usual trick of gimping a machine to push buyers into more expensive hardware. Great for Apple's bottom line, not so great for your average punter who just wants a basic desktop machine that can link to a few peripherals without swapping wires.
I would have thought most offices also have usb docking stations which handle all that in meeting rooms. 1 cable covers all that nonsense. If you work on an ultra book, you almost certainly have some kind of docking station in an office.
If your on Apple or most other ultra books your already used to the dongle/hub/docking station life anyway, there aren’t really any USBc versions of all of that stuff you listed either way.
I don't know if my usage case is typical or not. I have a MacBook with one USB-C port. In four years, I've never thought to myself that I needed more.
If I need to use any USB peripherals, I have a USB-C to USB-A adapter, I plug that in and plug the accessory in. Some time ago I did consider buying some kind of dock adapter thing but when I thought about it more, I realised I just didn't need it and so I never bothered.
As an entry level machine, the Air is going to be a serious upgrade for me and I wouldn't consider comparing it to a powerhouse. It'll do exactly what I do now, just much faster.
Sounds like you're talking about the Mini you are chained to a desktop then you can have a permanent wired hub. Cheap as chips and means you don't need to plug and unplug all the time. It might even be the case the monitor acts as a hub.
I imagine most will be using a bluetooth keyboard and mouse so for many people that only leaves the display, possibly an external HD or SD card.
Yeah, I don't get people complaining about number of ports on a desktop that has thunderbolt, just get a dock (thunderbolt or USB-c) and you'll have all the ports you'll ever need, and in a more convenient location too. If you need more than 80 Gbps bandwidth (two thunderbolt 3.0 ports), then a £700 device is not for you.
I’ve tried to follow the argument and I’m struggling to see why this is such a drama.
Fact is, the entry level machine (yes, it is entry, even if “more ports” is the only likely differential on portables at the moment) - with what should be significantly inferior hardware - is running rings around machines 5 times more expensive in terms of rendering time.
You can make arguments about plug-in compatibility, port availability (which frankly isn’t a big issue). But hardware to hardware I’m struggling to see how anyone can’t be impressed! And to dismiss it as a “mistake” .. yeah ..
I've largely stayed out of this thread because if I defended these new devices, I'd probably be called a fanboy. However, this comment sums it up perfectly.
Just wondering what people’s thoughts are between the M1 Mac Mini vs Ryzen 7.
I built a high spec 3800x pc a few months ago for video editing and music recording, but looking at the new Mac Mini, they look like they might actually be faster/better.
Also been looking at upgrading one of the PC’s at work and was going to buy a Dell Optiplex for about £650 (core i5 10400), but could stick my ryzen in work and get the Mac Mini instead.
In FCPX it looks absolutely fantastic for video editing.
This is test using a 8gb MBP, it's on par or better than the Mac Pro. It seems mostly about the GPU until you run the x86 version of Premier.
So far I'm impressed.
What are you talking about? According to Von (who I presume is more knowledgable than all the top engineers at Apple), this is doomed to fail...
:D
There are a few on here who aren't posting much sense whatsoever. It makes great for great reading. It's like Karen from Facebook...
