How do you guys test a card, especially B grade?
4 Feb 2009
So I've got a new 'B' quality card coming (2060) to last me until the current supply crisis clears up.
I want to really test it, make sure it's not a lemon. Thing is, I'm not really sure what extra tests to do. Furmark, ok. A few games benched. But what extra tests to prove that it's a good card?
Ta.
Sgarrista
Commissario
9 Aug 2013
Bromsgrove
Ta.
B cards are usually just damaged boxes or opened products. Load it up, run some benches if you want but just go play some games, it is more than likely fine.
29 May 2005
As above - furmark will see if there is any issue with cooling and if the stress of heat cause any issues with GPU or VRAM. Port royal does similar thing but more of a stability test also.
you can also run timespy to get a result and compare with online database for GPU score. If roughly similar then you are ok.
also have GPUz running at the back ground to monitor clocks and thermal.
25 Aug 2005
Do the usual as you suggested but also run some RTX stuff even if it's just the demos on the Nvidia site.
I bought a b grade 2080 from somewhere a while ago. It benched fine, ran furmark fine and crashed randomly as soon as it encountered anything with ray tracing.
OP
4 Feb 2009
Noted - that's especially useful
