According to the
CDPR updated spec image, your system is at minimum req for RT set at medium at 1080p although looking at the GPU they recommend, you sit in between RT medium and RT Ultra so between 1440p and 1080p. I would not be surprised if you get well over 60fps at the RT min settings on your high refresh rate monitor tbh or possibly even more. I think the spec screenshot not mentioning 2080 Super/Ti or 2070 Super is very deliberate. nVidia are on this game and they want people to buy the 30 series cards (even though nobody has any stock
) but we already know the 2080/2070 Ti/Super cards are powerful anyway moreso the OCd ones. I think the 2070/2080s have not been mentioned purely for this very reason, they are most likely are capable of solid performance but nVidia need to get people buying those 30 series cards although as mentioned, who the hell is able to find them in stock anywhere that isn't charging in some cases nearly £200 more than nVidia's own RRP?
DLSS is a bit more than just simple upscaling. You choose a display and render resolution and the tensor cores on the 20/30 series cards use AI to draw the image at a higher fidelity than native resolution. DLSS 2.0 creates a more detailed scene than the original resolution and you regain 20fps+ that you would have lost with just RT on and no DLSS typically. I've only played Control which has DLSS2.0 and this is based off my experience in that game.
