Oh ok I wont show the window then..
I assumed you would upload anyway.
Any option of just strapping on a fan?
There are fan mounts - I've now populated - just liked the old setup as it was practically silent unless you stuck your ear to the case and just about coped with an overclocked 4820K.
Don't understand my 3070 FE at all though - playing with the voltages just produces worse results though it seems to have plenty of headroom for lowering the voltage while still remaining stable at stock but doesn't give any higher frequency potential same with increasing the voltage... but if I ramp the core clock up with a slight increase to power limit while using maximum performance power setting the frequency goes up, the framerate goes up, but power draw... goes down! (any other combination of settings just produce worse results than stock with the power draw clipping the limit).
EDIT: With some more playing got it to +150MHz, 109% power comes back to stock power use - basically maxed out at 240 watt - not sure what is going on there (possibly a driver bug). Gives around 8-10% performance increase in games and ~2GHz frequency. At roughly +167 (I need to look up the bin steps) it loses stability but there is no real performance increase beyond +150 due to being on the power limit.
