your fishing worked a treat,always count on fanboys defending their brands to the death, wish i brought some popcornIndeed. Both AMD and Nvidia are scummy, and only a fanboy moron would bother thinking that one is "less worse" than the other![]()
Yep, 2012Mhz show’s performance improvement but it drops after that. Core clocking is where it’s at.GDDR6 will give you error corrections (so lower fps) if overclocked over 2150 or so. In fact you should check what is the frequency that gives you the most fps ( between 2000-2150Mhz ).
your fishing worked a treat,always count on fanboys defending their brands to the death, wish i brought some popcorn![]()
If there was a memory bottleneck, oveclocking the memory would lead to gains, but it’s core overocking that scales well from my testing.
Those tears are delicious.
Since you can't actually name what amd did other then price higher with low availability. I wouldn't call it scummy.
But sell all available stock to miners making people wait weeks/month. Along with all the other things mention and still defend them. You ate righ. It takes one to ignore all that.
Rolf
There are only 3 guys with multiple accounts. One has a 3090, one a 3080 and you with the 3070."Sell all available stock"... so everyone with FE cards in their sig is just making it up?
Yes i think the 2138 is the max the card is running but even with a modified bios, if you go over that you will lose fps.Think the OC reviews I saw the VRAM was always maxed out at 2140, never any higher. Guess that’s probably why then.
ROFL, scrumptious.There are only 3 guys with multiple accounts. One has a 3090, one a 3080 and you with the 3070.
A user from reddit has down some power limit testing with 3rd party software
seems the big Navi cards are either overvolted from stock or AMD has the overclocked the cards hard to make them competitive cause just like Ampere, Bug Navi retains most of its performance with significant power savings
you can maintain 95% of performance with a 20%/60w reduction in power draw
and you can maintain 75% of performance with a 50%/150w reduction in power draw
They're not clocked quite as hard as ampere though but still over their efficient peak, on the rtx3090 you can save 80w/22% and maintain 90% performance so the 3090 is overclocked from factory slightly harder than the 6800xt but both cards are clearly overclocked pas their peak efficiency and you can achieve significant power reduction for just 5-10% performance loss
You don`t need special tools to undervolt it, you have the setting in AMD control panel.What was the software? Igorlab stuff? I'm interested in getting the 6800XT but want to undervolt it.
It is pure speculation - if you actually go to the source of the information they only speculate that a certain amount came from cryptocurrency and then further down compare the mining performance of Ampere - the original report itself doesn't tie that income to Ampere only to crypto. It is the news articles that have reported on that which have tied the two together.
though isnt zen 3 more profitable than the gpu series, thats what i read, could be wrong thoughWatch the HU video and steve said that AMD told him they will have AIB at MSRP in around 4-8 weeks. That's around 40 days that I gueesed at before...ROFL
That's why I said I would just wait it out.
Ampere released on Sept. 17, 2020 and it's be about 73 days since released. About 2 months and even Steve admits there has been no signs of improvement in stock for Ampere.
IMO, AMD should put more priority of RDNA2 over Zen 3 since Intel won't have anything anytime soon.
I am not sure on that.though isnt zen 3 more profitable than the gpu series, thats what i read, could be wrong though
I think per wafer they are more profitable but I do agree with the priority thing from a business stand point.though isnt zen 3 more profitable than the gpu series, thats what i read, could be wrong though
I have no doubt they (Mining entity) will have muscled in early on the scene as it offers them access to much needed factors. The hardware out there was getting stagnant and Ampere/RDNA2 was a step up in performance for no price hike. They would easy have tapped into the supply chain especially in eastern countries where backhanders would be common. I guess it would perfectly explain why there is pressure on the retailers as the low volume manufactured was not able to spin out of the mess.
The Zen 3 server chips I would have thought would be higher priority than GPU, it's AMD's main battleground where they can really make a killing and push out Intels monopoly
