What's happening here?![]()
My weak legs probably.. I do try and do RDL all to the bottom but the most it goes is in between my knees and shins lol. Really need to get this 110 set to 10 then ill be happy with progression.
My weak legs probably.. I do try and do RDL all to the bottom but the most it goes is in between my knees and shins lol. This week has been tough, either barely reaching my targets or missing entirely. The combination of long working days and not having had a week off from the gym since the end of the first lockdown has left me shattered. Up to this point I’ve made decent gains week on week, but I feel really weak this week.
So. Next week. Do I take the week off completely to rest or do I hit muscle groups, but light and for reps?
Too many similar movements, too many sets, which I’m guessing are a bit easy as if I did 7 sets of bench I’d have nothing left for any other pressing.
Pick a couple of compounds for that day - ideally in different planes of movement - do like 6-8 sets total, then do a couple of sets of isolations for chest/tris/side delts. A good rule of thumb supported by the research is something like 10-20 hard* (as in <3 reps in the tank) sets per body part per week over 2-3 sessions.
Past the beginner stage, doing more is better than doing less for gains, but only up to a certain point: as you increase volume you get into something like diminishing returns where you can keep adding more but it doesn’t do anything more for you and just extends your workout time needlessly (called ‘junk volume’). Add more still and you start going down the other side of the hill where progress is slower, non-existent or you even start to backslide because the amount of work you’re doing is past your ability to recover from it properly for the next session. Something that always stuck with me I heard years ago was ‘do as little as you need to do to keep progressing’ - so if you’re not a complete beginner and doing say 12 sets for chest each week (both from compound and iso work combined) and lifts are all going up, why add more gym-time doing 13-20 sets if you don’t have to?
*most people don’t train hard enough and their ‘2 from failure’ actually turns out to be 5+ from failure when actually pushed in a sports science lab getting screamed at by a spotter - you can get a LOT out of a few sets if they’re done with focus and intensity. I don’t like training to failure but sometimes doing it for a session or two in a safe way can be illuminating as to what you can actually do vs what you think you’re doing and get you better at judging reps in the tank.
What's the best accessory exercises to increase BP? I can CGBP 70KG for 5 reps but max reps at 80KG BP is 4 so I think my chest is holding me back.
How long has your bench stalled for? Maybe look at where your recovery could be lacking ie macros/calories sleep stress. Maybe go down to 75kg and try to put more reps on there each week.
I would say almost 2 months. Since I started gym I've lost about 10 pounds, I am eating about a few hundred calories short of maintenance on most days but a few it is normal.
Sleep is good. No stress.
What is the que for the lats, do you need to squeeze them together? I'm sure once you start lifting they start squeezing anyway?
