Mistake? 10900K over 5950/5900/5800?
Caporegime
1 Jun 2006
Notts
for every one that said he/she got an issue there are probably another 100 don't have any issues. if you actually read through any of the issues, it is usually down to user installation erorrs, or not undertsanding bios settings with the odd few having actual hardware issues ie bad ram/cpu/board which will result in RMA.
people who has problem there are 100 other users who has none. the ones who have problems and dont know the remedies will likely to post on forums way more than happy customers. so issues arising on forum or reddit is not a holistic view of any particular trending issues. unless there is hard evidence it is much more wide spread.
also these issues can stem from user installation errors, the odd bad board or CPU, incompatible hardwares, not updating latest stable biosm, no doign fresh install coming from intel platform, dodgy software, overclocking without doing stress testing. these problems are also symptonmatic to intel related hardware and intel users. if you search forum for "intel high temp" "inte Ram not working" you get a gazillion of results. so your view point is extremely biased.
regardless of the post by Dg.
the OP just games and having a £600 part that is way over the top is not necessary. a £400 CPU from either intel or AMD will do you good now and for years to come and be at the same gaming perforance as the £600 part. that extra £200 can be used to pay the scalper for a new GPU or put towards a new PSU if you intent to go down the route of 3080 or 3090.
the thing is generally its true what i put about running a intel cpu over a amd one. far less drama to just get it working. go read through amd threads. you will see . amd to get the best out of them messing with progs for voltage , heat , matching memory lala you get the idea. intel cpu put in works.
29 May 2005
well as i said, people with problems will shout from the roof top more.
i switched from intel to AMD earlier this year. pull the build together, no dramas. swapped out a motherboard, no dramas & no OS fresh install required everything just worked when plugged in. bought a brand new CPU, mobo, and GPU recently - all installed and booted up no dramas. I didnt even have to do a fresh install of my OS when i swapped out CPU, Mobo and GPU, i was up and running in 2 hours, plus all the settings I had from the previous build worked off the bat on the new build with no dramas.
so for me no drama is my experience. you still use intel so how can you say there are issues from personal experiences?
the voltages, heat issues, matching memory all that LALA LALA flaff affect intel platform equally. if you dont know what you doing in the bios and set volts or OC sky high then you are asking for trouble. everything off the stock or default works fine on 99.999% of the systems like intel. the odd one will have broken hardware, like with intel. it is when people start to "tweak and tinker" is when they run into deep waters - intel OC also has similar problems - a quick search on this very forum yield people with RAM compatibility issues, heat, CPU not boosting, stuck OC clocks etc etc on intel platform. shall we say Intel is now plagued with issues also??
AMD gives you more scope to tune memory if you CHOOSE to do it to eek out more performanc otherwise XMP setting works out of the box just like intel.
not sure what you issue is with AMD.
7 Nov 2018
Direct Storage isn't here yet. We don't know what the hardware requirements are.
Direct Storage is what the Xbox is using. We can surmise that if there was no performance difference between NVMe and Sata, then they would have just used sata SSD's in the xbox to meet a lower price point.
Edit: Also, who wants to reinstall windows when the first decent game that utilises it comes out. I know I don't. The PC I am currently building, just like my current one will run on the same installation for as long as possible.
OP
8 Dec 2004
Hampshire
Folks. I dont wish this to be an AMD vs Intel calamity but
I think I have managed to get what I want from this thread.
Here is my summary
  • 10900 seems to be priced higher today compared to what it was some months ago. Supply and Demand has made an impact on this. Nature of the economy and the beast. I am prepared to swallow the extra 200 notes.
  • The Zens are clearly ahead of Intel for things like Cinebench and other CPU multicore intensive stuff. Thats given.
  • Intel seems to be slightly ahead on single core I believe?
  • Both points above do not affect me be because I am predominantly gaming on this new rig.
  • The 10900 seems to edge the 5900 and 5800 on most games but not all (similarly price CPUs)
  • The 5950 edges the 10900 in most games but not all (5950 200-300 more expensive than the 10900)
  • PCIe Gen 4 on Ryzens not on Intel, again not something Im personally fussed over, I think the rig I have (will have a 3080 inside it) is plenty for me for gaming at 3440 x 1440.
  • Appreciate comments on Direct Storage, but as of today I dont think this is a bottle neck for any games currently available or upcoming?
Thats pretty much what I have extrapolated from the comments made here, research on the internet (articles/YT) etc.
Fair summary?
Man of Honour
30 Oct 2003
Essex
It's DG that's the issue. He is the last Bastian for Intel, it used to be gaming, now it's DG :) Even when AMD took the crown DG was arguing otherwise! I doubt many would be recommending the 10900 over Zen3 simply because pcie/4, platform, etc etc... Right now unless they (Intel) floor the prices it's still AMDs market.
Man of Honour
30 Oct 2003
Essex
Here is my summary
Fair summary?
For the bullet points.
  • Intel seems to be slightly ahead on single core I believe? - Incorrect AMD have the single core lead and by quite a bit.
  • The 10900 seems to edge the 5900 and 5800 on most games but not all (similarly price CPUs) - Not sure where you are looking at these benches I make the 5000 series overall ahead in gaming. Even the 5600x is up there.
If I was buying only for gaming 5600x alongside that 3080 imo makes the most sense. Even the 10850/10700 make more sense as a gaming only machine. Mind you the 10900k doesn't just become a bad chip overnight, it's still a decent chip but buying today it just doesn't make as much sense as the alternative.
OP
8 Dec 2004
Hampshire
Cheers Vince. Apologies about the incorrect points.
Regarding the benchmarks, I should rephrase, the 5800 on some games is ahead and others its not. Check some youtube vids.
Also it is very subjective it seems since some review show the 10900 down in the dumps whilst others not.
I quickly checked videso of 10850/700 vs 10900, yes you are right about your comment. The difference between a 700 and a 900 is perhaps 5-10fps?
For a couple of hundred quid I dont mind, especially considering there are some people paying over a grand, going from 3080 to 3090 to get the same increase in FPS.
I think in my mind I am quite happy with the setup :)
If I was doing any of the stuff mentioned above, then no brainer I will cancel my order right now.
But what I am intending to use it for, its good for me.
Man of Honour
30 Oct 2003
Essex
I I recon thats the best way to do it. Am I happy, does it fit my requirements. Honestly any cpu from amd 3600 up and intel 9900/10700 up and your experience imo os going to be more than good enough.
Genuinely im on a 1950x on my main rig and there really isnt a game I have played where you would say it performs badly. Sure my 3600x is faster at gaming but its not enough to care. I think thats pretty much the situation if your not out there for e-peen and just want a good experience you wont be dissapointed with anything recent. As i said the 10900 is still a great cpu and that doesnt change overnight.
18 Oct 2002
South Manchester
<Looks at Xbox Series S from across the room>. I know very well what it is and the benefits. :confused:
I'm more concerned with CPU and chipset support. Intel have a history of withholding features artificially for new chipset and CPU releases as a differentiator to distract from still being on 14nm over 6 years later...
Caporegime
1 Jun 2006
Notts
the problem is you look at my posts as bias when there is none. i favour no side. like the guy above who quoted me and just assumed im only on intel.
amd havent took the crown. they cant even ship these super fast cpus. as there isnt any lol. also dont be biased and honestly say which is the easiest cpu to just use every day from the instalation ? intel or amd be honest. then if you apply bias go read this very forums. of recent times. many amd cpus dont like certain memory. pcs not even booting. crashing.heat and other issues. its not a new thing either amd have had this for a good while. they are great new cpus but even if quicker wouldnt you take that 1 fps less in a game lol for a easy every day life ? :p
Man of Honour
30 Oct 2003
Essex
I have over 100 Intel machines and over 100 AMD (all in production) in my opinion neither have an edge in setup, issues going forward etc. It's just not a thing. It feels like people looking for issues where there are not issues. I just struggle to agree with opinion where there is no basis in fact.
Caporegime
1 Jun 2006
Notts
as said take personal opinion out of it. go read some of the threads on here only in the last week for eg. it shows you amd do seem to have there fair share of issues. i would gather all the posts but its just too time consuming.
Man of Honour
30 Oct 2003
Essex
Its not opinion when it's tried and tested, if I hadn't deployed 100 Zen machines last month then sure it is opinion... My experience - 100 of each brand 0 issues on either. That's experience not conjecture. What you are looking at is the vocal minority. How many people are going to make a thread "this works great" - Or are they just going to enjoy their machine?
18 Oct 2002
Eltham
for gaming you will probably have the better experience. we had a thread recently called is there a reason to buy intel. amd fanboys dived in. now go read the amd issues with 5800 and 5900s in the cpu threads.
numerous issues need bios updates , memory tweaks lala the rest. intel drop in works. no bother. you got a great a cpu enjoy it.
Do you really need to make up lies to try and make one sound better than the other? Numerous bios issues! Memory tweaks! The box had red on it! gasp!
29 May 2005
you got those two points wrong.
- 10900K is miles below Zen3 on single core performance. like 10-15% lower than any of the zen 3 cpus
- on gamings, even the 5600X is better than 10900K. let alone 5800x 5900x.
22 May 2010
Minibotpc
Tbh it all comes down to your workload and resolution.
If you do a lot of multi tasking applications then Zen3 is the way to go if you can find one.
If you game at 1080p and want more fps then Zen3 is the way to go if you can find one.
If you only game AND game at higher resolutions than 1080p then a faster gpu is more relevant than a faster processor so grab whatever processor you can get your hands on whether it be intel or amd.
If you game and do multi tasking workloads then Zen3 again is the way to go.
10-15% isn't really that much if you're talking raw performance and looking at numbers unless you really need 700fps at 1080p on csgo :p
Caporegime
1 Jun 2006
Notts
go look at actual big games not amd games used by biased benchmark people. 5600x isnt anywhere close. only in amd games.
Caporegime
1 Jun 2006
Notts
as said go read last two pages of the cpu forum on here. scroll down. then look for amd issues. its not made up. its written by forum members having issues. memory choice is a MASSIVE thing with AMD cpus. has been for years. not just performance wise but to even start up or work. i dont see how people can even say that with a straight face and make out memory isnt a big deal with amd cpus. you know it is. yet people will still deny this.
20 Jun 2013
And now the thread devolves into Intel vs Amd again.
Op has a decent gaming cpu, yes it was a ripoff at £600, but that has more to do with retailers and Intel pricing, I personally would have gone for the 10900kf for £150 less.
The frame differences between the 2 brands now is imperceptible, unless you're running monitoring software to show you the fps.
For a gaming only rig OP could have spent less on CPu and put extra into gpu but since he has a 3080 the only way it gets better is with a 6800xt/6900xt/3090 and they are impossible to get/cost way more.
Buyers remorse is something that you get with pc building, sometimes it stings more than other times, ie buying a 2080ti 3 months before 3000 series launch, but you've got the hardware, and the rig, enjoy it for yourself and your needs.
You didn't buy or build it for anyone else
