£50 on Amazon if you get it with S&S. You can cancel the sub at any time after the order arrives if you don't want more.Evening all. Quick note to say that Master of Malt have Deanston 18 on flash sale for £55.55. It's already a bargain at it's regular price of around £64.
Tomatin is lovely. Check out their 14yo portwood.
Kilchomann is an interesting one. See what you think. I thought it was a bit meh and I don't think it's that great - yet. Lovely distillery, great people, interesting tour etc, but the end product is still lacking something IMO. Give it 5 more years though and I think it'll start to round off some of the corners on it. 10-15 years and more matured? Some things need time. I suspect the best is yet to come from this distillery.
Had a dram last night. Interesting. Very different to other peated Islay malts. It's more a sort of bonfire smoke as opposed to the medicinal smoke usually prevalent. Also I wasn't getting the usual blast of sea notes you associate with Islay. Perhaps that's the influence of the sherry cask?
I only find Laphroaig 10 medicinal (the Quarter Cask not so), whereas all Lagavulins and Ardbegs I've tried are very campfire smoky to me, but still different to one another in that note. Taste and smell are very personal things though.
Have tried a few over the last couple of years, I love Auchentoshan American Oak, Chivas Regal 12 is nice, but my favourite so far has been JW Black Label - just with some ice, absolutely love it! May try double black soon! Any recommendations always welcome along the lines of JW Black Label...?
PS> I tried 'Whyte & Mackay' whisky, it is the first time I have been unable to drink a whisky, it was truly, truly awful, I couldn't even have it as a mixer, it was THAT bad (IMO).
There seems to be a good way to add peat and a bad way.
It's a very detailed process these days, but originally peat influence in whisky was solely because it was the only fuel Islay had to burn to heat the barley and stop it germinating. The smokey influence from the peat (it imparts phenols and other compounds into the barley) was therefore not as a result of wanting to make the resulting whisky taste 'peaty', but almost just a by product of the production process.
These days, it's entirely by choice as the maltings use very precisely controlled heating to stop germination, and the peat smoke is wafted through the barley by fans; the heat from the peat is not required, but the smoke produced is.
The process of malting (and adding peat influence) is part of a distillery's character, and as such it's extremely precisely controlled with detailed instructions for the maltings. There are some great documentaries on the likes of the Port Ellen maltings on Islay. They do the malting for the majority of the distilleries on Islay, but each distillery has their own peating profiles they use.
Bruichladdich have their Octomore line, which takes things to the extreme, and it's all about the methods used to impart the phenols into the barley. They typically aim for the highest parts per million (ppm) of phenols in the barley of any Scottish distillery, but they do multiple releases each year with different ppm levels too.
Phenols do decrease over time though (I think it's as they oxidise?), so a newmake spirit that's fresh off the still is going to be more phenolic than one that's older. If you can, I'd recommend trying a distillery's multiple different aged releases (ideally all aged in similar casks like just ex bourbon) and seeing how/whether the peat influence seems different between them. I did this with multiple Lagavulins, and I really don't get on with the young stuff (aggressive smoke and new rubber tyres), but the older stuff just clicks.
It is most likely due to oxidation I suspect. There are other possibilities, like the phenols being in solution with the alcohol, and because of the low and consistent temperatures in Scotland alcohol is lost during maturation before the water is, meaning phenols would be lost at the same rate as the alcohol. It would be interesting to see how it would affect a peated American whiskey, a lot of that is matured in areas there are high temperature variations, meaning the water is lost before the alcohol which would leave it with a peatier flavour over time if that were the case.It's a very detailed process these days, but originally peat influence in whisky was solely because it was the only fuel Islay had to burn to heat the barley and stop it germinating. The smokey influence from the peat (it imparts phenols and other compounds into the barley) was therefore not as a result of wanting to make the resulting whisky taste 'peaty', but almost just a by product of the production process.
