2 Dec 2020
Hello!
New here and to building pcs, I needed some advice
I bought this pc cheap as a lead up to building my own.
when buying it I was told it can be loud
I wanted to know if there are any things I can change to improve these specs a bit.
Can I add more RAM? I was hoping to at maybe run Dead By Daylight on it but I think it will take a dive if I try.
here’s a picture of the specs any help would be great! Thanks in advance
UZutxEL
OP
2 Dec 2020
Hello!
UZutxEL
Thanks I’ll give it a shot! Much appreciated
Man of Honour
23 Mar 2011
West Side
Thanks! And yeah I figured haha this was just a cheap second hand one I got to tinker with and use till I get the courage to put one together from scratch.
If you really want to learn take it apart and put it back together, take pictures and notes as you go.
Putting a new pc together is not to difficult as you have all the manuals. Just have to be careful when putting the cpu in and not overtightning things. Loads of tutorials and videos to help you.
