Anyone have the MSI TRIO 3070?
  • Thread starter Thread starter rn2
  • Start date Start date
rn2
rn2
13 Mar 2017
England
I read that it is the quietest of all the 3070s. So I'm interested in it :D Not sure what the queue is like for it though.
Got the 3080 trio. And it is extremely quiet. Case fans are much louder.
Also with low temp bios on it, Max temps of 63-64 under load.
Very impressed with MSI’s cooler.
Tiniest bit off coil whine when uncapped FPS in menu screens.
Thank you very much! That sounds delightful :D Coil wine in those situations are pretty normal on a lot of cards I think. I haven't heard it on my 1070 since capping all my frames to my monitors refresh rate though.
@Alec potter I just watched a video of a noise comparison with a 3070 TUF and like you said I couldn't hear the gpu fans over the cpu fans. Which PSU and wattage are you using?
Thanks. To be honest I'll probably set my computer up in a separate room as I'll be air cooling and the ryzen and apparently their boost clocks constantly set the fan into overdrive and I can't be doing with that lol.
