Which card to keep 3070FE or RX6800
25 Feb 2018
Not sure which one to keep?
bought a used 3070 FE (£600) just before getting a new 6800 Powercolour order in on here.
could probably get my money back on the 3070.
gaming at 1440p ultra wide 144hz monitor. Mix of game styles.
advice appreciated...
26 May 2014
£600 for a used 3070 FE is ridiculous. If you can get your money back, you should do so. They're not even that hard to get compared to the 3080 one.
17 Nov 2020
Doesn't matter too much. They're roughly in the same ballpark. The 6800 is faster if you're not doing any raytracing, but both are pretty solid 1440p cards, with the 3070 you're getting DLSS, RTX Voice and all that - if you care about those a lot, stick with NVidia, otherwise just flip a coin.
14 Dec 2003
Ouch £600 for a 3070 FE
6800 benches better but you won't see much difference in real world
3070 is better at ray tracing if you play a lot of games with RTX enabled
Caporegime
8 Nov 2008
I'd probably be keeping the 6800. Both are great cards and 4K capable to some extent, but the 6800 punches that bit higher.
OP
25 Feb 2018
Ok thanks for the advice.
5600X cpu on order, so thinking I’m swaying towards keeping the RX6800.
what is the ‘future flash it to XT’ about?
Another option I may have is a MSI GeForce RTX 3080 10 GB VENTUS 3X OC for £750.
What about that option?
8 Oct 2013
Yes, but using that logic, why buy anything ever again?
He already has 2 cards from this gen and is playing with the idea of selling them both to buy a third? Stretching that idea a little bit. If you need the extra performance sure get a 3080 but that's up to you
6 Jan 2012
I have got a Ventus, its good but voltages are locked which is a bit annoying.
22 Feb 2019
Ost Angelnen
It's his money. Personally, I wouldn't spend mine that way, but who are we to judge? :p
16 Aug 2009
3080 > 6800 > 3070
He means flash the bios on the card to the 6800XT version which isn't power limited to same degree as the 6800 which means you get closer to a 6800XT performance for 6800 money... at the probable cost of more noise and heat (6800 cards are 2 slots wide and XT's are 2.5 due to larger heatsink etc)
OP
25 Feb 2018
Stop the £600 jokes will ya! :D
Does anyone think the 8GB VRAM on the 3060 may be a limiting factor over the next year or 2?
I like the fact the RX6800 has 16GB, maybe helps future proof a bit?
8 Oct 2013
to be fair it's one of those things people ask without really considering everything else. 10GB will be just fine for the 2 year cycle in all likelihood. Games are designed with current systems in mind so how beneficial do you think it is (apart from the few outliers that never run perfectly) for them to get ram bound on one of the most powerful gpu's? The whole lack of ram thing pops up pretty much every gen because one sides number is always bigger (sure the 970 ram sucked though). The gpu usually runs out of steam waaaay before ram becomes the issue
22 Feb 2019
Ost Angelnen
Some games might run close to the limit, if playing at 4K. But yes, generally speaking it's usually less of an issue than people believe.
Still, if you're paying these prices, less is definitely not more! :p
