It happens and can vary from unit to unit. My first 3090FE had absolutely mental coil whine that I could hear it from meters away. My replacement 3090FE with same PSU's was significantly better, aside from caveat HDMI 2.1 port on it was broken right out the gate so that has now also gone back
Can see that Hardware unboxed in there Q&A yesterday were asked about coil whine with reference to Hardware Cunucks 6800 review and mentioned they did not have coil whine on there 6800 or 6800XT units.
So yeah sadly I think it will be a lottery (after playing the lottery of getting a card!) in terms of coil whine variation on these cards.
As someone else suggested could try using it a bit before sending it back. With my first FE using it a fair bit did seem to reduce whine slightly, though will confess, may have been partly placebo at that point tuning it out. My replacement right out the gate without any burning in was quieter.
