Easy garden watering solutions
11 Aug 2015
Evening all,
I am sick and tired of watering my garden every evening in the summer, so I'm trying to find an easy solution for the lazy gardener.
I've tried soaker hoses and I've tried the kits you can buy online that clip together using awful fittings - both of which are (obviously) useless!
I have 4 waterbutts and a Titan clean/dirty water pump that I'd like to utilise if possible.
Do you have any time waving ways to water the garden?
OP
11 Aug 2015
Some of these replies!
I am concerned the pump wont have enough pressure for a sprinkler, even though is supposedly able to deliver 2 bar of pressure.... (it definitely doesnt)
7 Sep 2020
Gods Country
Why do you need a pump??? Connect house to outside tap and then to a sprinkler, leave run for however long. Switch off and enjoy the rest of the evening
