- 30 Aug 2018
Longer than the pcbyou mean longer than the pcb or longer than the card with the standard cooler ?
Longer than the pcb
It looks like they made the top acrylic match the length of the reference card rather than the founders edition. Still very compact compared to the standard cooler.yes the pcb extends up until the metal plate you see underneath the acrylic. Then the acrylic plate and back plate are about 1cm longer than the pcb, this could be because the pcb ends in a V shape so they might have wanted to protect it a bit better
Hey, that's looking awesome, sorry about the backplate delay. Glad you got it together in the end though.
How has the card responded to being watercooled? Better pc?
So the original plan was to use an EK-CoolStream CE 280 on top, which is 45mm thick. I had to revisit that plan, as I didn't have room to place the combo / res with it and ended up using a SE 280 instead.
Hi! Very cool build. I am working on a very similar build. I am in the process of getting the watercooling parts and have a question.
You mentioned,
From your pictures it seems that you do have some clearance up top. Can you elaborate a bit please? I almost bought the EK-CoolStream CE 280 but now hesitate after seeing your post.
Do love this mate, you've done a fantastic job with it.
