Recommend Case Advice
13 Aug 2011
Hi,
I'm looking to replace my current NZXT H440 with something that has good air flow and will show case my PC in general - preferably a glass type of case.
I'm also looking for advice on RGB lighting to make it look nice - but nothing too over the top. I'd like to keep the case and internal lighting a sort of blue / black theme to match the rest of my setup.
Any recommendations will be much appreciated.
Many thanks
8 Oct 2020
Lian Li Mesh 2 or Corsair 4000D Airflow have great airflow and glass side panels; also reasonably priced. The cases have RGB options otherwise just grab a kit with a controller.
OP
13 Aug 2011
Thanks for your quick response guys. I don't quite like the mesh front panel - although I can see it will be quite good for air flow.
I was looking at the CiT Blaze Mid-Tower ATX. Any thoughts on this as it's a nice looking case.
As you can see from the 2nd photo, I have a huge cooler that gets in the way of the components. Is there anything I can use instead of this big ugly thing? Perhaps some sort of water cooling option?
OP
13 Aug 2011
Artic Freezer 2 is the best AIO from reviews.
BTW I think your fan on your CPU cooler is pointing the wrong way.
There are a few different Arctic Freezer 2 variants. Which one will suffice?
a Couple of other people also mentioned the fan is the wrong way around. I didn't build the PC myself but haven't really had any heat issues luckily
4 Oct 2014
It's a 5 second change to clip the fan on the other side, you might aswell change it - you won't be having thermal issues but your fans will probably be working harder/ it disrupts case airflow.
The AIO is Arctic Liquid Freezer II CPU Cooler 240
27 Nov 2005
Guernsey
