Tried the same cable as you today and still no better. Had some flickering in ESO but WoW looked great. Surfing the web was the worst thing for me, ghosting of text especially when scrolling and colours looking very dark on some sites, even using the OCUK forums was a pain. Hooked my Dell S2716DG back up and all looking great again. Perhaps I just got a bad one but not willing to try again so sending it back.Tried out the Kabeldirect VESA DP1.4 cable. Flickering remains in TW:WH2, noticeable on light backgrounds at <50fps.
Few dead pixels as well ... back to the Dell it is sadly
Received this monitor this afternoon, and whilst I am pretty impressed, I cant for the life of me figure out why the entire Colour setting sub-menu on the OSD is greyed out for me?
Also, 1 dead pixel, and some flickering occasionally but not that often... Box was open when I received it too. Purchased from Overclockers themselves no less!
Some features on the monitor can only be used on their own or with other settings off, so they get disabled.did you ever work out why some menu options were greyed out for you? I’m having this issue now
Having HDR on or auto will disable most of the picture settings and the colour settings. Similarly using any I-Colour mode will disable all the picture settings.
Enabling Freesync will disable the Picture Mode settings (PBP/PIP).
MBR being on will also disable some picture settings, As will enabling HDR or Freesync.
Using Overdrive will disable Direct Drive, while using Direct Drive will disable most other features - HDR, Freesync, Overdrive, MBR, basically anything except colour and brightness settings.
Whats the limit weight for a monitor arm on this monitor? i can't find any info online.
Anyone have a problem where every so often the monitor just goes black and then comes back again? Not sure if it’s my laptop of course but I have a feeling it’s the monitor...
Hi guys, I found this monitor brand new for 450€, what do you think? After months of usage, do you recommend it? I know about the flickering issue (hope that's not going to be a problem), but other than that you have any important dealbreakers that can let me go look somewhere else for that pricepoint (even used)?
Thank you
Sounds like a dodgy DP cable. Are you using a VESA-certified one?
Just to expand on this, I've been messing around with overdrive settings and +2 looks horrible to meFor all those following this thread - be sure to set overdrive to +2 - it really lets the monitor shine and show off what it can do.
Yes it’s a Maxonar one VESA certified. That’s a sign of a dodgy cable though is it?
That's really odd.Just to expand on this, I've been messing around with overdrive settings and +2 looks horrible to me
Can definitely notice heavier black smearing in games, +1 is maybe manageable but I will probably stick to 0 for now.
+2 is definitely worse for me, didn't even need to use a test website to notice it. Noticed it straight away in games. I think it is overshoot but it does have a smearing effect to it, kind of like a shadow is always trailing everything.That's really odd.
More aggressive overdrive settings should reduce dark-level smearing, at the cost of some "haloing" or overshoot.
Getting more black smearing with more aggressive overdrive is pretty much the opposite of what you should be seeing
It should be noted that that on some VA panels the dark level smearing is still really bad even at the highest overdrive setting. You might just not be seeing the level of improvement you expected...
