Nevermind, cracked it
https://www.3dmark.com/3dm/54718673?
CPU: 5950X
GPU: 3090
Total: 20006
GPU: 21189
CPU: 15201
CPU: 5950X
GPU: 3090
Total: 20006
GPU: 21189
CPU: 15201
I think that that GPU run was about 2400MHz, I have not touched the power limit on the card as yet. It can definitely go further, especially once I get a waterblock for it.Just out of curiosity, what settings are you running on your 6800?
had a play with a 5800X you can get 13k cpu score pretty easily @ 4700mhz all core
didnt like it returned it tbh.
i need that a go on a 5950X for 17K scores now!
Stick with Intel for PR and Timespy. I’m capped at 23000 Gpu score. Get the same whether it’s at 2160 MHz or 2220 MHz. Had same results at lower and at 2235 which I didn’t submit. I’ve given up now. Port Royal is even worse
https://www.3dmark.com/spy/16226588
https://www.3dmark.com/3dm/54411626
Timespy extreme though works well as do the others.
https://www.3dmark.com/spy/16304762
Tried running mem lower at 748?
Worth a shot. Sure I read somewhere that 748 mem is optimal as that hits the 21gbps max spec for the mem on these. It's where I hit my highest score as well...
do we have a TS extreme thread?
I had alittle play last night!
