What are these clips called?
19 Jun 2009
Central Scotland
...and where can I buy them?
https://ibb.co/hcnHnJv
These are used for clipping the water pipes to the heater matrix in a 09 plate Peugeot 308. One of the pipes came off the other morning, mid overtake of a HGV, in the pitch dark, filling the passenger compartment with steam and hot water!
Went to a French car dealership this morning and they said the clips come with the pipes and that'd be £120! :o Been round a few car parts shops this morning too and they weren't much use either.
Thanks,
FB..
Have you got a photo of what it clips on to for context? I'd be looking at maybe a jubilee clip or something tbh.
how did the clip come off, undue pressurization ? did the pipe collar it was gripping on break ? was it correctly installed ?
bend it slightly ? or wrap a jubilee clip around it in the horizontal plane of picture
https://ibb.co/YLb2L3y
The clip grips around two different diameter flanged pipes to form a union, one pipe is the hot water from the engine coolant, the other is the flow/water in to the heater matrix.
Not sure how it came off, I think the pressure as the clip was still in situ-ish, however I forget if it remained on the matrix or the pipe. Potentially not fitted correctly, been doing some work on the heating lately, however, now fitted correctly doesn't create a watertight seal/some play in the union.
What a stupid design. How the hell that passed scrutiny is amazing.
I'd refix it and stick a jubilee clip around it.
Thanks,
FB..
Are these the correct parts?
https://www.ebay.co.uk/itm/Peugeot-...689110?hash=item34192d27d6:g:tEYAAOSwFuJd1rse
Seems like the clips are green plastic in your second picture as in the set i've linked to..
I don't think so. The green in my second pic seems to be an insulation type foam used as a kind of PTFE tape to seal the input to the matrix.
Pop it back on the two pipes, the way it's meant to be, and then pop a jubilee clip over it to hold it in place.
That's not going to work, sadly.
Thanks anyway lads.
