- 16 Dec 2020
Thought I might ask this here after seeing this old post. https://forums.overclockers.co.uk/threads/guitar-wiring-help.18731300/
Recently got a few upgrades for my telecaster with the intention of putting the pickups out of phase with a 4 way selector switch and also splitting the hotrails bridge pickup into a single with a push pull tone pot.
Push/Pull = split hot rails
position 1 = Bridge
position 2 = bridge/neck in parallel
position 3 = neck/bridge out of phase
position 4 = neck
I have flipped the control plate and pots to get the volume closer to the play area and the selector switch further away. I have taken a diagram of of an image search and removed the wires in paint then moved the pots and flipped the switch so it matches the layout I currently have. the third wire on the neck pickup has been added also.
If anyone here has a clue how to wire this up or could point me in the right direction it would be a massive help.
Here is the Diagram.
position 1 = Bridge
position 4 = neck
