realbench Vs game stability? 5800x
5 Nov 2020
Hi guys,
Been tinkering with the 5800x quite a bit now to bring temps down and make it as quiet as possible. Currently running it with a -0.03V dynamic vcore offset, with amd curve optimiser set to -10 or -20 depending on core and a tdp of 110. Temps are around 65 or so on a stress test.
I ran realbench overnight and was stable for 7-8 hours or so, i turned it off this morning. Jump into assassins creed valhalla and it crashes within 15 mins twice. More voltage needed?
How can i tell if the crashes are based on Bios/cpu settings and not voltages? Is there any tool which can log this stuff. I hear AC Valhalla crashes for a bunch of peopel so may not be the best indicator..
Might I be better off stock full auto and putting up with 85C/noisier under load?
Any tips, cheers!
6 May 2009
Try lesving it on PBO auto then try assassins creed valhall for 30 mins.
If it works you know its curve optimiser causing the crash
OP
5 Nov 2020
True, that would almost be too sensible! Ill save my current settings on a new profile and change one thing at a time..
OP
5 Nov 2020
:) I would save profile, then load defaults with XMP. Do your other stuff (if any) like disabling onboard sound then test.
DOH! Silly me. I realised I have a fairly aggressive OC on my GPU with afterburner. I should probably turn that off before stability testingthe CPU in game! that's probably why it passed all the benches but maybe cause some instability with afterburner
EDIT: Actually seems to be more of a problem with ubisoft games in particular and some cloud saving.. Oh well :D
OP
5 Nov 2020
Weird, realbench is my number one stability software. Never crashed in AC.
It was happening With a few other ubisoft apps. Turned of rivatuner and cloud saves in ubisoft settings and seems to have gone away... I remembered if I pass lots of stress tests it could be something else. Low Nd behold I think it's resolved now.
8 Oct 2020
What cooler are you running? I’m only hitting just over 70c with R23 multi-core test using an Arctic Freezer 280mm, so even lower in games as they barely stress the CPU.
OP
5 Nov 2020
I'm using an NHd15. Pbo and auto oc with default mobo settings gets lower 80s :( still having a couple game crashes with the undervolting and low power limit. Might just run stock after all this faffing.. NHd15 is a beast of cooler too.
8 Oct 2020
Ah right. I haven't done any overclocking on the CPU yet purely because it hasn't been needed yet - games hit the GPU bottleneck first. PBO2 looks a lot more promosing though, I think you'll get more joy once launch it.
OP
5 Nov 2020
Yeh not trying to overclock but just limit the Tdpi guess to control temps bit more
